With all of GM's supply issues, my new 2500 still has no build date and will be missing some features.  I have just been offered an existing 3500 instead, which has all of the features I wanted except for the 5th wheel package which the dealer can install.  So ..  do I go with the 3500? Really reluctant to go bigger as I was actually considering a 1500 this time .. and worried about classificiations ===you know, when the government decides to make you safety and when they don't, lol.  Seems like the weight difference isn't much, but .. .wait for the 2500?  or go with this one?
Previous generations this was more of an issue as they capped the gvwr at 10k for the 2500 up until ‘20. Since then they are both well over 10k gvrw so I doubt there would be much difference, escpecially of you don’t already know because of certain regulations that you need to adhere to.  I actually had the opposite problem, I wanted a 3500 becuase they are more capable for essentially the same money with no drawbacks but all I could find was a 2500.  I would do it
The only real difference is the 3500 has an extra leaf spring. I believe the brakes are bigger too. Get the 3500.
Extra leafs, higher GVWR, 12 inch axle on diesel.
Otherwise everything else is the same srw 2500 vs srw 3500.  Engine, trans, brakes, etc.
I ordered a 2500 Denali with the 5th wheel package. I preferred a factory install since it'll come sealed and undercoated.  I've had a dealer installed 5th wheel and comparing them both really like the factory install.  I'd wait for the 2500 for this and the ride as others have commented.
I've had both already.  Zero difference in ride between the 2500 and 3500.  (I have the 3500 now).
I think I would go with the 3500, you can always haul lighter, but you can’t haul heavier. As soon as you start looking at trailers......
+1 on going with the 3500.  Depending on the state you can register both a 2500 and 3500 as 10k to stay under the limit so you don't need a dot number if you run it for your business.
I rated my 2500 at 10k GVWR to allow me to pull a 16K trailer without a CDW license.
^^^ What he said!!!
I would stay away from the factory hitch, that is the only thing I'm not happy with on my truck.  The goose ball is loose in the hitch and now it will not unlock and come out of the hitch.  Should have put a B & W in it and thrown the factory one in the trash!!!  Just my $0.02  your experience may vary!
:jester:
I use the B&W goose ball (TruckProUSA B&W GNXA2061) and it works great.  This is with the factory hitch.
better to have more than enough than not enough.......all things being equal with just an added spring in leaf i would go for 3500
if there was a serious ride or money issues maybe not.....but they are basically same in every way cept for more capability and they have it right now.....i would think a 3500 for anyone who tows and needs a HD.....they are such different trucks than a 1500
My vote is 3500. See too many people maxing or almost maxing out payload on 2500. I wouldn’t go 2500 anymore. 1500 or 3500.
Your money though and you spending a lot of it so make sure you are happy with your choice.
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
    • 185k on original 6.2L engine and 10 speed. 6" lift with 35" tires. Changed oil (Mobil 1 synthetic) when truck told me to. Original tranny with original fluid and no service or flush done. All highway miles. A/C compressor replaced at 155k. Oil cooler line replaced at 180k. Still daily driver. Love this truck.   This is my 3rd 6.2L vehicle (2008 Yukon Denali / 2018 Cadillac Escalade) with over 150k miles and no issues. Denali had broken motor mount at 100k.
