I have a 2021 trail boss with 300 miles AND EVERY TIME I TURN OFF TRUCK THE EQ GOES BACK TO 0 its so annoying has anybody found a fix ?
I hate that you have to always turn the radio back on too after turning truck off. When you remote start the truck it always blows cold air full blast! have had my truck only days and really regret getting it now.
Yea, the reset worked for me too.  I did both the audio and truck settings (yea, had to reconfigure door locks, windows, etc.) just for grins.  Figure GM flashes a custom set of Infotainment/audio settings at the factory but probably from a different firmware image or something.  I went from a 25 year old truck to this 2021, so despite being in IT, I'm still learning that my new truck is actually a computer that happens to have an engine.  😉
Guys, can you talk more about the reset? What did you do and how long now has it kept the EQ settings?
So same issue with my 2021 Silverado 2500HD LT
2 weeks old and it would not save the settings, radio wouldn't come on when truck was started.
Did the complete reset this morning.
As for now the settings I set this morning have worked all day and the radio is on when I start the truck.
Go to settings and reset system, I had 2 options ( don't recall what they said) but I reset both.
Had to enter phone info etc and reprogram the favorite stations but it's worth it as long as it is solved.
Will report back if it fails.
Thanks for the info about reset.
These are the steps I followed to reset the radio in my truck:
1) Browse the radio menu's to Settings > System > Return to Factory Settings
2) Select Reset Vehicle Settings
3) Wait to reset
4) Select Erase Settings and Personal Data
5) Profit
I reset my radio on 4/16/21 and I haven't had a problem since.
3) Wait to reset
5) Profit
Thank You Random
Exactly what I did
2021 Silverado RST having the exact issue. I just purchased the truck a week ago. I found this topic searching the issue. Thanks for the reset option. I will try it today.
3 hours ago, David Jankowiak said:
I’m having the same issues in my 2021 Silverado LT. the equalizer resets to zero, and the volume goes way loud when starting the truck. This is highly annoying!
Do a system reset in settings, it worked for me and a few others on here.
On 3/16/2021 at 10:00 PM, SSCHUU said:
Most every time I start up my truck I have to reset my Equalizer settings. It goes back to the default settings. 0 across the board. Does anyone else have this problem?
I’m having same problem with my 2021 rst Silverado
Go into settings and scroll till you see Reset I don't recall exactly where but its there.
There will be 2 options , I did the reset for both.
You then have to program the radio again, phone stations etc..
Mine has been fine since I did it 2 weeks ago.
Good luck
I am new here, but I created an account because I was having the same Equalizer issues, where it would reset to all 0s once the vehicle turned off. I have a 2021 GMC Sierra, and the way that I got it to stop doing that was to go into the vehicle settings and tap the audio tab. from there you can set the equalizer setting to what you want. It was stopped resetting since.
On 3/21/2021 at 2:46 PM, Trail Boss 2021 said:
I have the same issue. Seems very strange that you need to reset every time you start up.
I hope there is just a glitch..........
I have the same problem. Pain in the ass.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
    • This landing is worse than most. Patchy blacktop with washouts, soft gravel/sand at bottom that washes out with every heavy rain. I tell everyone to put it in 4WD. A lot of them think they can pull out their trailer in 2WD. They end up digging a hole and then putting it in 4WD.  The lake is a pristine lake and has a lot of money on it. There are several wake boats and lot of large tritoons. The people with the money don't want it improved because they don't want more traffic.    Boat Landing 1.jfif Boat Landing 2.jfif Boat Landing 3.jfif
    • How wide are your rims?   Toyo specs 8.5-10.0-11.0 inches. My thought would be rim might be pulling the tire inwards creating a center that is more pronounced.    I also noticed that the spec sheet says max 65psi. So you could be right lowering the pressure to ~40 psi.
