Looking to get a hard tri fold bed cover. There are a lot out there but was wondering if anyone care to share the likes or dislikes of what they’ve had or have. Thanks.
I recently installed the BakFlip MX4. I like it a lot. It is my first bed cover so I have nothing to compare it to, but the finish is high quality. Installation was easy enough that I was able to successfully complete it in the dark by myself. It creates a pretty tight seal... we haven't had any torrential downpours since installation, but so far its keeping the water out.
I'm using the Backflip MX4, while it's not 100% watertight I'm fine with the way it works.
Another MX4 here and love it.  Installed one on mine and on my buddy's easy install just take your time do it right. Best thing about it is that even when full open I can still use my rear view camera as it does not block the third brake light. Very easy to remove fold it up two knobs at the front remove. All black anodized hardware.
Edited by WeGone
Another with the MX4.  Advantage versus some other is that when folder up and leaning against the cab, it's still lower than the high mounted camera so you keep that functionality.
I've always bought the Extang Solid Fold 2.0 - its different than the others because it sits on top of your bed, rather than installing rails and it being more of a flat mount.  Doesn't look as nice, but I use the bed of my truck quite a bit and was always afraid if I took my cover off and had the rails I'd break something, so that was my reasoning.  Leaks very little, but its def not 100% watertight.  I will say its one of the first 1-2 things I buy when I buy a new truck.  I love how easy it comes on and off.  Again doesn't look as sharp as the flush mounts, but that's something I never really cared about.  Install takes about 5 minutes.
I got the GM hardcover one, was an accessory on the truck when I bought it, have always been a soft rollup user.
I like that:
I can put stuff on it because it's hard
The front 1/3 lifts up and has a lock
Doesn't sag
It's more secure than a soft rollup (never had issues in the past but this is a plus)
I don't like:
not water tight, hard rain or car wash gets water in on the rear corners
I can't fold it up against the rear window so when I need the whole bed above the cover I need to remove it, probably weighs 40lbs?
If I still had my ATV I'd have never installed this just because of how often I'd have to load up the bed over the rails but with my current use case I'm going to keep running it, I only have to pull it a half dozen times a year, I can cram everything else under it or pop the front or back 1/3.
I had intended to buy a Backflip MX, but found something a little less expensive and given its many good reviews, thought I would give it a shot.  It took about 30 minutes to install and it keeps the weather out just fine, but clearly is not as nice looking as the BF MX.  I have used my bed quite a bit since installing the Gator SFX and it is super simple to fold it up and roll it back out when I am done with hauling whatever.
https://realtruck.com/p/gator-sfx-tri-fold-tonneau-cover/v/gmc/sierra-1500/2021/
Edited by Kilgore Trout
My first tonneau on my current truck was a Rough Country hard trifold.  It was a good cover.  Very effective at keeping water out.  I liked that it was very easy to remove if I have an oversize load.  Only reason I got rid of it is because I have the GM Accessories sportbar and that got in the way of the tonneau being able to open after the first section.  Would've been the same problem with all the other tonneau cover recommended.
Edited by Transient
I also have the Gator cover.  Very water tight, and if you put a seal on the tailgate, no water gets in.  While I agree that it doesn’t look quite as nice as the BackFlip, it blends very well on a black truck.  Doesn’t cost as much either.  Very solid cover, and took just minutes to install myself.
The gator looks like a soft top. Is it?
I have the BF MX4 myself. I like that it is a hard top so the bed is essentially a trunk and I can feel safe leaving expensive items in there.
My Gator is a hard top.
    • Not sure about DFM tech but i know there's a stop/start deactivation button.
    • I could be interested if they axed cylinder deactivation and at least have a button for stop start. I’m sure the HP numbers will be higher. I would want a longer warranty to help build confidence. I’m a less is more guy as I get older. A V-8 work truck model would be my choice. I know a few outfitters for custom additions I prefer.
    • It's official. GMC pulled the covers off the next-gen 2027 Sierra 1500, and we got the first official look. Full breakdown here: https://www.gm-trucks.com/next-gen-2027-gmc-sierra-1500-v8-trim-changes/   The quick hits: SLE and SLT are dead. The new core retail trim is just called "Elevation". Two new V8s, a 5.7L and a 6.6L built with high-performance Corvette architecture roots. No horsepower or torque numbers yet. The 2.7 TurboMax finally ditches the old gearbox and gets the 10-speed automatic. AT4X moves to larger standard 35-inch tires with front and rear e-lockers, Multimatic DSSV dampers, and heavy-duty Jounce Control Dampers. Over 60 inches of combined display on Denali Ultimate and AT4X, complete with a motorized articulating center screen and an adaptive passenger screen. Seven simplified trims across the entire model line to clean up ordering confusion.   So let's get into it: New 5.7L and 6.6L gas V8s with custom active exhaust tuning and a Corvette connection. Is this the exact engine lineup half-ton traditionalists have been begging for? Purging the iconic SLE and SLT names after all these years to lean entirely on Elevation as the high-volume core. Bold move, or a mistake? That motorized articulating 16.3-inch screen that slides up to reveal a hidden dashboard vault. Awesome mechanical theater, or does it make you nervous about long-term durability? Physically lowering the headlamps in the front fascia to improve road courtesy and stop blinding oncoming traffic. Smart real-world engineering, or does it hurt the truck's aggressive stance? What trim are you putting your name down for on day one? Drop your first impressions below.
    • My overnight hospital stay turned into five.  I developed a post operative fever and an erratic  heart rate.  A blood clot in the lungs was the culprit.  This is apparently a common post surgical complication and easily remedied.   I was the youngest in a four bed ward and a Doctor with a Geriatric specialization was in charge of my care.  All of the nurses were good and some were outstanding at dealing with old people.  It was very evident that my age triggered a different level of care!  My advice to any senior going for a hospital stay is to have a trusted family member advocate visible.  If not, you will still be well cared for, but you may discover that your voice  isn't as strong as it once was!
    • $4.25 85 oct. in town, down 50 cents.
