Does anyone have experience with belltech lift kits? I've seen plenty of positive reviews from their lowering kits. They've been in the suspension industry for a while, just not so much the trail or lift side.
Long travel is the end goal, but a $700 coilover kit with a 5 yr warranty vs an extended strut sounds more functional.
I'm considering the adjustable 3-4" lift coilovers, part #15203.
-Helper spring
-60mm damper body
-35mm independent valves
-20mm piston rod
I've got a 2020 z71 with the 3.0 Duramax for those needing an image to work with.
Still exploring UCA options. 35*12.5r17 will be the tire size.
Probably going to order them next month.
  • 3 months later...
