This is my first post here so cut me some slack if it's in the wrong place.. Anyway, I recently bought myself a 2013 Silverado 2500, gas 6.0, 4x4 & on the drive home taking the highway I noticed there is little shake/vibration when on the gas when going 40+. Nothing bad at all, just seems to run less then smooth while on the accelerator going 40 & over. It completely stops when I let off the gas & just coast. It feels like its coming from the engine but if not then idk where it could be coming from.. Up till this point I've read it could be the driveshaft or U-joints, which are not looking to healthy, very rusty. Anything else it could most likely be? Odometer currently reads 50,500. Thanks in advance!
Edited by CowboiCadillac2013
Odometer 50,500
  • CowboiCadillac2013 changed the title to 13 Silverado 2500 shake/vibration while accelerating
I'd say it's a small chance it's a u-joint but you never know.
My first thought is torque converter shutter, fairly common issue to the 6L80/90e transmissions.
Yeah I've read torque converter as well.. Fingers crossed its not anything worse than that.. Assuming it is the torque converter, can anything else be damaged from driving it around like that?
Yes. If the truck is driven a lot you can start to have pieces of the converter go through the transmission oil pump. Then that whole piece, which is also the entire bell housing needs to be replaced.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
