2024 l8t . Ac has never felt really cold even new. But lately it seems a little warmer. When it gets in the upper 80s and a little more humid it just does not keep up. And sometimes at idle it gets warm. My wife's 2008 envoy is better. My son's 2016 is colder. I have an apointment for a third try Monday the 29th at a third dealer to try and get cold ac before my warranty is out. The first two told me something about so many degrees under ambient temp blah blah blah seemed like they didn't want to mess with me. This was set at low. Max air fan speed high. 87 degrees and a little humid.
Edited by Aimatdeer
AC in home or auto only cool down 15-25 degrees from outside temp, but what will help is to put the ac in recirc mode this will recirc the Inside cabin air rather then trying to cool down the outside hot air, I always have mine in recirc mode.
I call B.S. when I first moved to Texas my first house would only cool to 80 with the Texas heat. The AC tech said it was normal at 100 degrees outside. I remodeled the house put in a new AC. I could hang meat. My cars may need recirculating to start. Once moving it switches to regular AC and I could hang meat. Living in Texas no one would put up with only 20 degrees difference.
Mine is in the shop for the AC now. While it did get cold after a bit, it would take a while to even start to cool the air at all. Turns out the compressor was bad and cycling.
I was using recirc/max air. Especially if it really hot i start out by lowering the front windows a little with regular ac the go to recirculation after a few and rolling windows up. And it does not have the newest refrigerant. It has per the info under the hood r134. Not the new r1234yf.
Edited by Aimatdeer
OK you say you could hang meat but what was the actual temp? One of the AC systems job is to remove humidity that we feel on our body your new system removed alot of humidity as that is were the water comes from on the ac coils and that made it feel colder. 80 degrees with high humidity will feel hot vs 80 degrees with low humidity will feel alot cooler.
My house is set at 75. My car at 70. When I have guests the house is at 70.
That a/c has got a problem. It should be able to put out at least mid 40`s temp on a day like that.
Vent temp, that is.
Edited by PunchT37
Hard to say what the issue might be. Anything from the ability to cool the AC condenser up front, to blend door issues in the HVAC unit, to refrigerant charge, to compressor issues or issues in the lines.
Report back what the techs find on the 29th.
GM has service publications which list acceptable vent temperatures and AC pressures at given ambient temps and humidity. They probably won't touch the system if it's operating within those ranges.
I'm also surprised to hear your 2024 with the L8T is still using R134a? I was pretty sure the HD's had switched to the new refrigerant around 2020.
If that guage has a way to adjust [hex on bottom], put that thing in a glass full of ice, put water in, put your gage in, let it sit for 3 minutes or so, and set it to 33 degrees.
Edited by PunchT37
The thermometer has been in my wife's 2008 envoy, my sons 2016 chevy, my friends 2020 1500 silverado all showing cooler readings. It's not the guage.
20 hours ago, Atlas said:
Hard to say what the issue might be... to blend door issues in the HVAC unit...
My 2008 started exhibiting similar symptoms, wasn't 'cold' enough. I went through a pretty extensive diagnostic process for a DIY'er with limited OBD access. System evacuation and recharge included.
Noticed one day the passenger side was cold (I'm never over there so took awhile to notice).
Pulled the drivers side blend door actuator out, disassembled it and cleaned it out. Put it back in and did some kind of reset and it fixed the problem.
Long story short, it wasn't the A/C system at fault, the blend door wasn't moving to full cold position.
Seen this gen truck with bad compressors.  Also bad blend door linkages which requires replacing the entire HVAC box, but those ones are for getting two different temps driver vs. passenger side (cold on one, hot the other).
EDIT:  Performance chart with MAXIMUM outlet temperatures.  So depending on ambient temp and relative humidity, you should see temps no higher than the column on the far right out of the vents.
So @Aimatdeer if there are no leaks, the charge of refrigerant is correct, and everything is operational (compressor, temp doors, clutch fan), it might be on the high end of normal per this chart.
Edited by newdude
Even on a hot/humid day, vent temps with a thermometer should be 40-50F coming out of the ducts when set to the coldest temp.
Is there a spec on what temperatures are acceptable vs. not acceptable?  My '24 has fairly weak AC as well but I don't want to waste my time or the dealers time if it is still in spec.
Just edited my response with a performance chart I found.
    • Not sure about DFM tech but i know there's a stop/start deactivation button.
    • I could be interested if they axed cylinder deactivation and at least have a button for stop start. I’m sure the HP numbers will be higher. I would want a longer warranty to help build confidence. I’m a less is more guy as I get older. A V-8 work truck model would be my choice. I know a few outfitters for custom additions I prefer.
    • It's official. GMC pulled the covers off the next-gen 2027 Sierra 1500, and we got the first official look. Full breakdown here: https://www.gm-trucks.com/next-gen-2027-gmc-sierra-1500-v8-trim-changes/   The quick hits: SLE and SLT are dead. The new core retail trim is just called "Elevation". Two new V8s, a 5.7L and a 6.6L built with high-performance Corvette architecture roots. No horsepower or torque numbers yet. The 2.7 TurboMax finally ditches the old gearbox and gets the 10-speed automatic. AT4X moves to larger standard 35-inch tires with front and rear e-lockers, Multimatic DSSV dampers, and heavy-duty Jounce Control Dampers. Over 60 inches of combined display on Denali Ultimate and AT4X, complete with a motorized articulating center screen and an adaptive passenger screen. Seven simplified trims across the entire model line to clean up ordering confusion.   So let's get into it: New 5.7L and 6.6L gas V8s with custom active exhaust tuning and a Corvette connection. Is this the exact engine lineup half-ton traditionalists have been begging for? Purging the iconic SLE and SLT names after all these years to lean entirely on Elevation as the high-volume core. Bold move, or a mistake? That motorized articulating 16.3-inch screen that slides up to reveal a hidden dashboard vault. Awesome mechanical theater, or does it make you nervous about long-term durability? Physically lowering the headlamps in the front fascia to improve road courtesy and stop blinding oncoming traffic. Smart real-world engineering, or does it hurt the truck's aggressive stance? What trim are you putting your name down for on day one? Drop your first impressions below.
    • My overnight hospital stay turned into five.  I developed a post operative fever and an erratic  heart rate.  A blood clot in the lungs was the culprit.  This is apparently a common post surgical complication and easily remedied.   I was the youngest in a four bed ward and a Doctor with a Geriatric specialization was in charge of my care.  All of the nurses were good and some were outstanding at dealing with old people.  It was very evident that my age triggered a different level of care!  My advice to any senior going for a hospital stay is to have a trusted family member advocate visible.  If not, you will still be well cared for, but you may discover that your voice  isn't as strong as it once was!
    • $4.25 85 oct. in town, down 50 cents.
