I installed the Fast Headlights 35w Mini D2S projector upgrade on my 2019 Silverado 2500HD LT. Upgraded the low beam bulb to the Phillips Phillips XV2 Extreme Vision and high beam to Morimoto 2Stroke 2.0 LED. Very impressed, super bright and they were great to work with. I did mod the install through the dust cap using a cable gland. Essentially a pig tail with connectors on either side so I can completely remove the cap & pigtail to easily replace and reconnect the bulb. The gland is on the lower inside corner of each cap.
I came home to this today. I ordered the Morimoto kit from TRS. I got the 4500k 35w setup. Unfortunately, probably won't get to them until next weekend. I'll update with my progress.
Edited by Jfaulk
Misspelled
Where did you get the cable gland
I would be interested in replacement caps also.
I used the incorrect drill bit and cracked both of my caps during the install. I patched them up with RTV and a roll of electrical tape but I sure would like a redo to make them look more professional.
Looks like I should have come here first, but I might be ok anyway? So I have a 2015 SLT Sierra and thought I was going night blind. I got these without doing too much research, but they seem to have improved matters thus far.
https://www.amazon.com/gp/product/B07K27LJC4/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
I’d ditch those ASAP if it were me. I had a set of similar LEDS in my 15 Sierra SLT before I bit the bullet and went with HIDs from TRS. BEST MONEY IVE EVER SPENT! The LEDs scattered the light so bad it was worse than OEMs when driving in snow at night. The HID kit I’ve got is the Morimoto 5500K 35W and they light the road up like it’s daytime.
You can find oem ones on gm parts websites just do a google search for oem silverado headlight access covers for your year make sure you order the correct ones as the top and bottom are different sizes!
Thanks. Yep, they are about $20 each. I’m interested in the details about the oversized ones.
 here are the extended ones. I think you could possibly make somethi g similar for alot less money if you are creative and handy. I wish there was a rubber universal type that would fit but I have yet to find one..
Link to extended https://www.shapeways.com/product/FTQHHLVEP/a-single-thinner-extended-silverado-headlight-cap
link to oem https://www.gmpartsgiant.com/parts/chevrolet-cover~23215569.html
Edited by Greytrout15
Compared to stock, it's much improved. I also don't feel much like tearing apart the front end.
The only thing I had to take apart was the air box. Granted my truck came with projectors so no need to tear much apart at all.
Perhaps I did not understand the process. I also have projectors. I had thought folks were disassembling factory headlights and replacing the projector units.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
