Update: MY TRUCK IS FINALLY FIXED!!! Am I allowed to say what each dealer did and can I mention them by name on this forum? Not that I want to turn this into a dealer bash session but at this point I gotta vent!
I would like to know what your fix ended up being.
First Step: Back to dealership where the truck was purchased to rebalance the GY LS-2's on standard balancer. They left the old wheel weights on and added more weights but still vibrated.
Second Step: Went to a local tire shop for Road Force balance still vibrated. All weights were removed and all new installed, still vibrated.
Third Step: Back again to the dealership where the truck was purchased, had GY LS-2's replaced with Michelins. They again left the existing weights on the wheels, respun on a standard balancer and added more weights, still vibrated. (I won't even talk about the attitude and disrespect I had to deal with or the condition of the truck when I got it back.) I dropped the truck there on (2) different days for 8+ hours each time.
Fourth Step: Found a new dealer with a RF balancer. Waited in the waiting room, (2) hours later no more vibrations! Smooth as glass all they way up to well over 75 MPH!!!
The second dealer was VERY professional and explained exactly what they found on the RF machine. The right front wheel being the worst had 35lbs of road force. The other wheels had 8lbs, 18lbs and 19lbs of road force.
So I guess in the end the Goodyears were no good and unable to be properly balanced with a RF machine. The Michelins, though not balanced properly from the first dealer were able to be balanced by a properly trained tech. As it stands I am extremely happy with my truck now!!
Wow I'm happy for u...I went through hell too w the dealer..but i have the michilins now and never been so happy to drive the truck at any speed and no vibration or shake whatsoever...
Congrats to u glad Ur done w the shake)
Believe me I am too quickvert1! If anyone wants the name and number to my GM rep I will provide it to you. If everyone uses the the same rep it could possibly expedite the process.
The key is to not let these dealers / parts changers tell you its in your head because its not. If something is vibrating there is a reason!
That's great, you gotta be happy to have that behind you.
Let me ask you guys this...I've got about 6k miles on my truck, been great. I feel a small vibration in the floor, gas pedal starting about 67 up through maybe 75-80. Above that is seems to quit. I don't think it's anything like you all describe, or it just hasn't bothered me as much. I mentioned it to the dealer when I had it in for service and they road force balanced the tires. 11, 11, 15 and 9 lbs. added 1/2 oz to 2 of the tires. It's better than it was, but I still notice it. Probably just because I'm looking for it. Honestly, had I not read this forum I probably wouldn't notice. It's a very rhythmic vibration. I can feel it for a couple seconds, then quits for a couple seconds, then does it again. Over and over down the highway. Looks like there are a number of folks with different issues and probably not all the same thing.
18 inch Goodyear RS-A's. Same deal or no?
Edited by RM4665
I too have that rythmic vibration, but I think thats because its spinning at such a low RPM as the truck is being pushed along. I would describe it as more of an audible not physical vibration. If I put mine in M5 it seems to go away. I can live with that, just turn up the radio lol! It reminds me of riding on an airplane once it reaches altitude and they throttle it back...you just have a constant rythmic drone if that makes sense...
My issue before was that I couldn't put my head on my headrest without my eyes bouncing around...
That makes sense and is a good analogy. Though I can feel it in my feet, Mostly the floor board. The balance did seem to lessen it, but it's nothing like the head shaker you describe
I been on and following this thread since the beginning I also have a mechanical engineering degree. So here is my take. There are mainly two completely different vibrations which are not related to each other being posted here.
The first is obviously the higher speed vibration which seems to be related to improper wheel balancing. These new trucks are using higher strength steel and are more sensitive to Harmonic vibrations then ever before. Having your wheels and tires perfect is a must.
The second is a audible vibration caused by the cylinder deactivation and exhaust. I bought one of the first in the area and had no issues concerning this until I had a computer update. Mostly felt when the motor is at a low rpm for that particular gear. I blame this on our governments mpg/emission laws.
There are a few random problems mixed in the forum as well, (This is to be expected with any manufacturer) that resulted in a vibration.
Hopefully GM will pull their heads out of their ars and fix these issues.
As I mentioned before in earlier post my worst problem is hauling a light trailer. I think it's the tire problem magnified. Just haven't had time to go back to the dealer with the trailer attached.
Edited by Szyikowski
Hmm..my road force was very high with 2 tires..
The goodyears are not the greatest. .
Went for a test drive last weekend in another truck w those tires and I felt vibration..lol..but my brother wasn't buying that one anyway
It's amazing how many times you hear about people having their tires balanced several times and they are still wrong. When someone has work done to a vehicle it would be nice to trust the shop knows what they are doing. Someone should start a thread for reliable tire shops, rather it be a dealer or not. People could post names and locations of tire shops they've been to and recommend.
Got to thinking about this on the way home last night. If it were the case, I would think it'd go away if I put the truck in neutral while rolling down the highway. Gave it a shot and it still did it, about 67-75mph. Comes and goes in a consistent rhythm. In that scnerio the trucks not being pushed along anymore.... Am I right? Does that put the cause in something from the transmission back?
Hello everyone. I am having a very subtle vibration as well, it is in the steering wheel, gas pedal, headrest and i feel when sitting in the passenger seat from the floor. It is a silverado crew cab v8 short box. I felt it on the test drive and told the sales man he said he felt it too, tried to get another truck but did not have another black available (or so they said). He had me drive another one with 20" wheels and different tires on it, i have 18" wheels with goodyears on it. Had the truck for two weeks now and find myself enjoying it except on the highway. took it back to the dealer and they said that the road force was good on all the tires and that hey used some vibration analysis tool that gm had and 20 or lower was good while driving, and my truck was 11. I was an auto tech for five years (lexus and jaguar) and have a degree in automotive technology, and it seems like bad tires to me, they are saying they are good, anyone have these tires and get them replaced. Service manager also told me if i was not happy they would bring i the field service engineer and he has all this special tools to narrow it down. this is my first chevy and i can say i am disappointed thus far, has anyone gone down this road yet and if so was it resolved for you?
thanks Mike
thanks Mike
The tires are the culprit..u need to get new ones..get a second opinon.another dealer or someone u know and trust..most dealers are liars
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
