On the subject of axles.........
Google Automotive News---GM pickup launch slowed by AXLE SUPPLIER.
Ironicallly their name is American axle and gear.. Location Silao Mexico. Is it just me that can invision the GM purchasing execs. screaming at that co. to get the axles delivered no matter what it takes?
My truck shakes like the one in the video but worse at times. I really think that it involves the before mentioned "stacking effect" ( several out of tolerance parts getting in harmony) and a bad rear axle assembly. People that ride with me agree it seems like it is coming from the rear. But I would not bet on it. I think there is a combination of flawed parts that add up to the variable intensity that my truck has. It ranges from not acceptible to "keep the coffee stirred or shaken".
Check out the article.
I was told months ago by a gm tech I've know for 20 years the issue is axles by american axle corp... I'm going to change my axles and put 3.73s in a few months. I'll be taking to a chassis shop first to have them document what's wrong since gm can't get there shit straight.
Not sure if anyone else with a vibration has noticed this, but can you take a look at your axle lengths for me? I only noticed after i put my offset rims/tires on. Did some measuring from frame to wheel, frame to tire tread, etc.. Found the drivers side rear tire sticks out about a 1/2" less than the passenger side. Actually 1/2" less than all the other tires. looks stupid. In other words, my drivers rear tire is in the wheelwell 1/2" more than all the others.
Could my shorter axle be an issue related to these intermittent bad vibes? I pointed it out to the service manager, he just brushed it off and said oh its only out about 1/4". It is noticeable..
9mos and almost 9k miles and still living with my vibration which has stayed pretty much same between 73-80mph with most pronounced vibration felt at 76-78mph. Was hoping after 10mo's it would get better or GM would figure it out...I've been thru many dealer attempted fixes including...new tires, new driveshaft, shim in rear end which was later removed, new larger diameter exhaust with no flapper valve, removed all of the BS plastic "skid plates" , engine mount shim...that pretty much covers it. So disappointed because otherwise like truck and engine...I have read every single post from pge 1..my .02 here is we are dealing with terrible tolerances in Mexican built drivetrain, stiff frame, and a horrible transmission which makes a ton of clunking and is constantly clunking and lugging the truck in too low a gear...that collectively result in our vibrations. Mine has gotten more pronounced in the steering wheel in addition to always there seat and pedal...so fact that GM techs are more aware of identifying the issue, but yet after replacing nearly everything but transmission, tells me this is not a single mechanical failure but a collection of poor tolerances, horrible transmission, and stiff frame. Bottom line GM has ****ed us on a 50k truck, and they do not and will never have a proper fix...those that press the issue legally have gotten GM to relent and buyback trucks yet the 15's have similar problems. See GM has not fixed the issue because the issue is related to many engineering and build problems...no doubt having cheap Mexican parts and labor only adds to their inability to properly fix the problem. I leased and look forward to my 3yr contract ending so I can get out of this POS truck.
i hope he is right or you will have lost any chance to go back to GM for anything even with documented proof the parts you removed had issues they will just say it was within tollerances they deam to be satisfactory
Edited by keakar
Nothing wrong with Chinese or Mexican made parts some say. Well, this past weekend I bought a new 10 cu ft refrigerator. It is made in China and is blowing nothing but hot air straight out of the box. I have had it with this Chinese made crap.
And feel free to read about Ford Mustang Chinese made manual transmission problems. Lots of problems.
Edited by pm26
I've been through one buy back and it took 7 months. I'm not going through that nightmare again so I lowered this one and I'll try to fix it myself since GM doesn't care. Maybe I'll FedEx the parts to Mary.... I'll never buy another GM product
I've followed this thread very close and GM is jumping to automatically assume the tires are the culprit to the vibration issues. Then, they are tackling the rear differential if the tire road-force balance and/or replacement does not solve the issue. A last resort is a buyback or trade for a 2015 model.
But what about all the other 2014 GM vehicles that potentially use the same Goodyear tires such as the vans and full size sport utility vehicles including the Tahoe, Suburban, and Vans? Historically, GM has designed vehicle platforms so there would be a certain amount of interchangeabiltily of components. My 97' GM K1500 shared the same engine, transmission, rear end, brakes, etc. as the 97' GM Tahoe, Suburban, and Van.
Wondering if these 2014 vehicles are experiencing vibration issues as well?
No. All parts and components for those are made in Sweden and Germany in class 10,000 clean rooms by technicians attired in white lab coats. :rolleyes:
http://www.gm-trucks.com/forums/topic/165595-my-suburban-2015-ltzs-issues/
Edited by pm26
So I saw a video where a guy jacked up the rear end, took the rear wheels off and then took a hydraulic lift and raised the arm up so that it barely touched the hub. Then they started the engine and put it into drive. You could clearly see the wobble in the axle and as it made a full revolution, it would come into contact with the arm of the hydraulic jack. It showed that the axles are the problem. I'm tempted to do this same thing. Obviously the Chevy/GM dealership aren't going to fight for something for us, so maybe we need to show these videos to our GM Service Managers?
if you jack up your truck by the rear differential so the rear wheels are off the ground, they start tthe engine and put the truck in drive and let the rear wheels rotate, you should be able to see up and down movement of wheels if the rear axles are bent.
Edited by pm26
Yes, but that doesn't show if its the axle or the rims or the tires.
Then you take the wheels of and attach a dial caliper close to the outer edge of each axle flange and take your readings. Heck, even a concrete block with a piece of 2X4 placed close to each flange will give you a good idea off any radial or lateral runout. If you notice excessive movement, you need to remove the axles and determine if the axle shafts themselves are the problem. It could also be badly machined axle housing where the axle bearings are pressed in, or even bad bearings (not very likely).
I can report that my new Michelin ltx ms2 tires did not solve the problem. It did remove the knocking sound from the tires at 45, but vibration at 75 is still there.
Fwiw, these tires are much quieter and have better wet weather traction that the goodyears...
Do you have a link to the video? I can't find it, was it a 2014?
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
