Canada does have what is called CAMVAP which is like an arbitration process. Bought my 2014 Sierra 4x4 CC Z71 back in August and the dealer has had it for a combined 11 weeks . New rear end, tires and various other parts and RF balance and it still vibrates. Dealer has been very cooperative and is aware if not fixed next try CAMVAP will become involved.
I've had family members that have used the CAMVAP process and it was painful to say that least. Once it was all said and done, they felt it would have been easier just to trade the vehicle in at a different dealership and save themselves the time and stress.
Take it to another dealer. It is obvious that this dealership is using these excuses not to work on your truck because they have no idea how to fix the problem.
They don't get paid to find a problem, they just get paid to fix it once found I believe.
Sadly, I have to add my truck to the long list of ones with vibration issues. Bought in Sept 2014, 2014 Sierra CC SLT Z71 4x4, has 2200km on it. It's had a bit of a vibration from 65-75kph, strongest at 70kph since new only in the steering wheel, definitely couldn't feel it in the peddles or body or anywhere else. So it wasn't too annoying and I honestly think it's the wheels/tires, so finally last week took it in and described the issue and me and service agent agreed it seemed like a balance issue.
Dropped off 8am, said they had a busy day, by mid afternoon said they need to keep it over night because they ordered 2 new tires because both on the right side would not balance in spec. So they keep it until the next day, get a call in the afternoon that the new tires are installed and balanced but... still a slight vibration from 70-75kph. He said they can keep it and keep checking the driveline for a bad ujoint, driveshaft etc. or I can come take it for now and see how it is. If I don't like it they can proceed with more work next week.
So I pick it up and sure enough it's like the vibration has been narrowed down to more like 70-77kph. I wouldn't necessarily call it less of a vibration, just different, like a bit higher frequency, and actually slightly more annoying than the previous initial vibration that was over a wider speed but slower frequency, and I swear there's a hint of it in the gas peddle now where as there was none before.
Anyhow, that's a bummer, and I swear after reading on here I'm still maybe gonna push going another round on the tires and wheels. Because they definitely changed the vibration with 2 days of adjusting and 2 new tires. I'm weary of going down the long road of tearing apart the driveline on my brand new truck.
But check out the work order and tell me if it looks like the second of the 2 new tires they got was also a dud with an initial road force balance of 32 lbs and then machine said couldn't balance... then what? the guy said F it and threw it on anyways?
Here's the w/o:
Looks like you need more tires. Spec for 14/15 Silverado/Sierra is 14 or 15. I'll have to look at the tsb again.
Thanks. Would you be able to send me or post the tsb so I can take a look at it?
PI1345B (partial)
  1. Document the before and after Road Force Variation (RFV) numbers on the vibration worksheet located at the end of this bulletin.
Road Force Specifications
P-Metric tires on passenger cars
15 lbs (6.8 kg) or less
P-Metric tires on light trucks
LT - tires on light trucks
Note: These numbers are lower than what is currently published in service information as some vehicles react to parts that are near the high limit. These numbers SHOULD NOT be used if you do not have a tire speed related disturbance.
Repair:
  • For any assembly that has an out of balance condition (greater than 0.25 oz), remove the weights and correct the condition utilizing normal balancing techniques.
  • For any assembly having RFV measurements beyond the specification above, vectoring the tire on the rim should be utilized prior to tire replacement. If this does not bring the assembly within specification, the tire should be replaced.
  1. I'm SO glad it's not just me. Now let me say that I came out of a Honda Ridgeline that I ran flawlessly for 7 yrs. maintenance free. As my friends say I have graduated to a big boy truck. I have recently purchased a 2015 GMC Sierra 1500 with the All Terrain package ( I have 750 miles on it). I have also noticed a slight vibration in the truck. In my opinion it feels like the shift points are off and it is in to high a gear. I have a feeling it has to do with the fuel management system that shuts off some of the cylinders. Once you put your foot into it, it goes away and runs perfect and smooth. I have owned several trucks throughout my lifetime when I had my own construction company. My trucks ranged from Fords and Chevy's to the Honda I just came out of. The reason I say all this is because I'm not a suit and tie suburban dad that just bought the truck to look cool. I bought it because I needed a bigger vehicle. I'm taking mine in tomorrow and I hope there is something they can do to fix the problem.
  • I'm SO glad it's not just me. Now let me say that I came out of a Honda Ridgeline that I ran flawlessly for 7 yrs. maintenance free. As my friends say I have graduated to a big boy truck. I have recently purchased a 2015 GMC Sierra 1500 with the All Terrain package ( I have 750 miles on it). I have also noticed a slight vibration in the truck. In my opinion it feels like the shift points are off and it is in to high a gear. I have a feeling it has to do with the fuel management system that shuts off some of the cylinders. Once you put your foot into it, it goes away and runs perfect and smooth. I have owned several trucks throughout my lifetime when I had my own construction company. My trucks ranged from Fords and Chevy's to the Honda I just came out of. The reason I say all this is because I'm not a suit and tie suburban dad that just bought the truck to look cool. I bought it because I needed a bigger vehicle. I'm taking mine in tomorrow and I hope there is something they can do to fix the problem.
For those experiencing vibration, I trust the vibration is in both V4 and V8 mode, because it would be a waste of time to try to fix vibration that is only in v4 mode. V4 mode will definitely generate some vibration and the bottom line it - we are stuck with it. A V4 engine is inherently rough running. Counterbalancing can correct it, but then it would be horrible in V8 mode. So, GM has to balance it for one or the other, but not both. Since V8 mode is more important, that's where it gets balanced. Bottom line - if V4 mode vibrations are too bothersome, then a GM is not for you. Get a Ford Ecoboost. Not trying to be a smart ass, but that's an unfortunate characteristic of these Active Fuel Management engines. Alternately, get a programmer from the aftermarket and turn the AFM off.
Tbarn, any change you could be so kind to post a like to where I can download the full TSB PI1345B? Would like to have a copy to put with the rest I've been collecting on this issue.
Those revised limits are very low. If that is what is truly needed to get rid of the vibration, then we are in for a ongoing pain in the butt. As the tires wear, the RFV will change and if these vehicles are so sensitive that they need perfect balance and RFV, well that will not be good. Maybe on a Ferrari, not not a pickup.
Btw, I just helped a buddy swap out the wheels and tires on his BMW. Hunter RFV values after balancing were 7, 24, 23, and 27 lb for the four. Car is smooth as glass all the way up to.... Well, I better not say. Let's just say the speed limiter on the Chevy will have kicked in. So, if that car doesn't need perfectly balanced/RFV wheels and tires, why do these trucks?
Troubling, to say the least.
Nope, no difference between V4 or V8 mode for my vibe. It is different depending on how hard I accelerate or decelerate through it.
I had a 2007 Avy, so I've already had my fun with first gen AFM issues like mysteriously burning a quart of oil on a 2hr trip randomly once or twice a year.
Edited by Adster
PI1345B (partial)
Repair:
Thanks, that will probably help. I think on mine I gotta find out what went on with that replacement tire that wouldn't balance and they possibly threw it on the truck anyways to see if it was good enough. Hope not, that would be a bad way to start things off.
Edited by Adster
I have had my truck in the shop for over a month. Road forced the stock goodyears twice (didn't help), got new goodyear all terrain adventures w/ kevlar (my favorite tire, have had on multiple trucks - didn't help), replaced one of the new tires that was slightly out of spec (didn't help), road forced again (didn't help), GM engineering sent my dealership this fancy vibration analysis device.
They took apart my front diff and replaced the ring gear (4x4 vibration that I honestly didn't even notice but the shop foreman did) and put new Michelin LTX MS2 on it (for the high speed vibration), road forced, and voila, it's fixed!! :):)
They had the Goodyear rep at the dealer over this as well, and he said that TONS of sierras are having problems with Goodyears (especially the Z-71s with 20s on them).
Edited by crheming
My truck came from factory lifted and giving me the run around will never buy another truck from Chevy Somerset Kenny Ross in Somerset Pa. Once they got your money its funny how they act . Service manager trying to say it's normal to shake ! So my steerung wheel shaking was a design by Chevy? I can't toe anything because it's like driving in a helicopter ! Less then 10000 miles has frame rust
4 appointments service manager forgot what he told me, second one he set up and wasn't even there. 3 hour round trip for nothing thanks Ray Service manager at Somerset Kenny Ross
They say not suppose to use auto . Keep in 2 wd then why did you make auto ?
Still shakes In 2 wd
can't use auto?
This is like a bad joke they just don't want to pay back the money I paid out sad day for Chevy
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
