If this is true, GM should be able to hold their supplier accountable for the costs to replace the rear ends, no?
Does anyone know if this was a new supplier or a new line for our trucks? Do they make all gear sets or just certain ones?
they changed the method for how they cut the gears. supposedly they went from a 5 step to a 2 step
All good....just picked it up and the new tire & road force balance did the trick......
huh? so have you already had it in the shop for vibration?
I'm going to start a class action suite against the LT owners who go it for free.
I'll give mine back if they give me full MSRP so I can change brands, I don't like this feature
Edited by Jesse D
Do they require rear end replacement with 4k miles on the clock?
GM was so much more efficient than that! Truck was delivered with that requirement already built in.
My point, however, is that some of us have been lucky enough to get our vibes fixed. It's one fine truck vibe free.
Legally, I believe that GM is responsible for ensuring that parts meet specs before installation. Cutting corners, in this case, is costing GM big time, unless the customer accepts the "performing as designed" b.s.
Sure, but if the root cause was a bad batch of parts, GM in theory shouldn't be as resistant to fixing this since they shouldn't have to eat the cost of parts and labour. They should be able to recover the costs from AAM.
AAM may not have been cutting corners while cutting gears. This 5 to 2 cut process seems interesting and ironically was designed to reduce nvh.
Either way, it looks like GM engaged and have found the issue(s). This is great news.
GM has provided the vibration feature as standard equipment on a select number of trucks.
I think on one of there commercials they refer to this feature as perfection .
Edited by TheFactor
This was discussed before and someone stated that their truck which was repurchased by GM showed up on his dealer's lot as a "certified used vehicle" several weeks later.
Buying back to GM means finding another sucker to buy the same truck.
When I was having problems with my Sierra with the frame coating peeling , the CARFAX listed "inspections" and "serviced" when the truck was traded in and hit the used lot. Some other poor sap ended up with a " beautiful like new " Sierra - raining rust from underneath.
If you are buying low mile used- best to ask for the dealer service report on what was actually done.
They have ????? Well what is it, we would all love to know !!!!!
More than a few reports in this thread of folks that have had their rear end replaced without any improvement at all. Now were they replaced with more defective parts, who knows.
I'd be interested in knowing what everyone's road force balance numbers are.
they don't matter, they aren't the root of the problem. GM has actually dropped their allowable spec to below industry standard to try to reduce the vibration.... it hasn't worked
Still dicking around with mine, waiting for the GM to figure a solution....
I still go back to thinking about Electronic Power Steering Software issue..
I have good RF on rear tires, Fronts are slightly high with 16 and 21 RF numbers.
Getting a slight vibration in fronts on straightaways, highway speed sweeping turns excites the vibrations.
According to the Smooth Road Shake Software, it should compensate for slight out of balance conditions.
Why is it not compensating? The following comes directly from GM advertising:
Has anyone tried or had their service department reset the software for this?
Electric Power Steering System
The belt-driven electric power steering system features an integrated electromechanical power steering unit, containing the power steering control module, its sensors, the power steering motor, a belt drive and a ball nut mechanism.
The power steering control module is part of the power steering assist motor assembly and is replaceable as a complete unit independent of the steering gear assembly. The torque sensor is integrated with the steering gear pinion and is serviced as part of the steering gear.
The power steering control module has a software feature referred to as Smooth Road Shake Compensation that reduces steering wheel vibration caused by an imbalance from the front tire/wheel assemblies. The vibration transmitted to the steering wheel is referred to as Smooth Road Shake and is a phenomenon that occurs only at highway speeds and on smooth roads. The power steering control module employs active controls to sense and reduce the periodic torque component applied to the steering wheel caused by the wheel imbalance force. This software feature will compensate for a specific range of imbalance.
In addition to smooth road shake, road crown is compensated for by the steering wheel angle sensor signal, which calculates the intended driving direction. The Electronic Brake Control Module (EBCM) receives serial data message inputs from the steering wheel angle sensor.
The steering wheel angle sensor does not require centering often. However, if the steering wheel angle sensor is not correctly centered it may create a lead/pull condition. If this condition is encountered, always perform the Steering Angle Sensor Centering procedure in SI before performing a wheel alignment
Edited by 14silverado4.3
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
