3 hours ago, Barak said:
.....My next step is continue driving and monitoring to see if any changes occur but did tell them I will be taking my cousin’s 2019 year model same exact truck on same roads to see if his exhibits the same shake/vibration at any speeds. Stay tuned!
Having the dealer compare your K2XX vibration to a T1XX makes no sense.  They do not have the same frame. They are the next generation truck.
 Basically they said that they let some air pressure out of rear tires to make ride more comfortable otherwise they feel truck is within “GM’s specs”.
I guarantee you paid double for your truck what I paid for mine and I still wont accept the "GM SPECS" BS. If they cant correct a known and faulty product, they need to buy it back or replace it with one that is "NEW CONDITION" meaning its a fully working product with NO issues.
The people who just "Deal with it" not only empower GM to not stand behind the company made issues, its also lining the pockets of every corporate monkey in the company.
My 2 cents (because GM got the rest)
So Brianibew, you’re saying 2018 and 2019 are not the same frame? How do we tell? The trucks body is exactly the same from interior perspective. GMCJoe17 - you are right about the price aspect. However, I am now only 1000 miles on this truck and I feel I am starting to get comfortable with it. Never owned a diesel so I want to explore everything but it’s never late to go back and tell them I am still experiencing it. Maybe it’s just me too little since I went from F250 to Denali, to mention that F250 was gas, rough, bumpy, etc.  and I only drove F250 for several months. I think time will tell too but based on what Brian says, I will have to comapre 2018 to 2018 in my case. Thanks all!
4 hours ago, Barak said:
So went back in to dealership due to shake/vibration at 70-75mph speeds. They examined everything on truck including taking it for a ride prior and after and couldn’t duplicate what I told them my issue was. Basically they said that they let some air pressure out of rear tires to make ride more comfortable otherwise they feel truck is within “GM’s specs”. After our conversation they did tell me to continue monitoring and certainly let them know if it changes like gets worst. They did also say that I will feel little stiffer and possibly shaky/vibration at instances due to heavy duty truck especially being diesel etc... I do get that aspect and I told them interesting to learn that for high end expensive truck. I did indicate to them that when at 55-65mph speeds, the truck rides smooth no shakes or anything but as soon as I am on thruways/highways at 70+mph it tends to pick up. My next step is continue driving and monitoring to see if any changes occur but did tell them I will be taking my cousin’s 2019 year model same exact truck on same roads to see if his exhibits the same shake/vibration at any speeds. Stay tuned!
Batak, I basic have the same truck only it’s a 2015. Mine is smooth as glass at all speeds.
Well that’s great. I have Goodyear Wrangler SR-A which came stock and I haven’t heard much positive about them. I still feel that the vibration is due to balancing, I just don’t find this dealership’s techs to be as experienced as some independent tire shops that do it day-in and day-out for many years. And this forum has informed me that my stock tires are just unbalancable when it comes to road force balancing. I wish I could drive someone’s 2018 model like my just to see if anything is different/similar.
Now reading you are referring to a diesel, I assume you have a 2500?  I was talking about the half tons.
Edited by Brianibew
I haven't been on this site for quite some time so I apologize for lengthy post,  I was hoping that this thread was pretty much dead and someone had found the fix for the dreaded Chevy Shake.  I'm sad to see that's not the case.  I gave up after countless hours and thousands of dollars, I replaced damn near everything underneath the truck including the drive shaft even though I knew it wasn't the issue I was desperate for a fix and it was a failed hail Mary attempt.  I followed this thread from the beginning and posted quite a bit while I was in deep trying to find a fix it this was about the same time Jesse Davidson was fighting for a buy back and traded a brand new Denali in for an F-150 at that point several competing dealerships knew about the vibration issue and were offering pennies on the dollar to trade or flat out refusing to take a GM trade in.  Basically a few trucks got fixed with tires a few with shocks a few with drive lines and a few new rear ends or swapping the factory axle shafts for a set of Yukons but they are the exceptions and the majority have an inherent design flaw that is causing a third order harmonic vibration.  Generally nth order vibrations are weak and absorbed by the mass of the machine/structure but when the input frequency matches the natural frequency of the machine/structure you have resonance and the vibration is magnified.   So here we are with another batch of consumers trying to find a fix for a problem that a fix doesn't exist and GM barely acknowledges that a problem exists I'm sure many people have been told that your truck is "operating within the GM specification for NVH" an abitrary number that didn't exist until this issue did, I feel for you guys I really do I have been there.  For anyone still trying to fix their truck because the cost to get out of it is too high, you first need to determine the frequency of the vibration you're feeling at a given speed.  At 70 MPH a 12.5 +/- hz is a first order tire and probably a balance or runout issue.  Multiply that by your rear end ratio say a 3.42 which is roughly 43+/- hz this would be a drive line that has a balance or run out issue.  Now the 38+/- HZ this is a third order tire and this is the thus far unfixable chevy shake.  The problem is that at 70 mph nothing on the truck is rotating at that angular velocity that's how you know it's a harmonic of the tire speed and there's a whole slew of parts rotating at the same angular velocity as the tires, harmonics are never a balance issue.
My story; I wanted out of the truck for quite a while but wasn't willing to take the financial hit, gave up trying to fix it and just dealt with it.  Vibrated like clockwork at 68 MPH plus.  I drive a lot of California freeway, speed limit is 70 on most stretches, afters 3 years I had 70k miles on the truck and the vibration had gotten worse, to the point I loathed the truck.  Add in the new issues that were popping up, leaking passenger side door seal, failed AC condenser, premature brake pad failure, the slide pins had stuck and were not allowing the inside brake pads to retract, outer pads had 60% left on them and inner pads were almost down to the rivets, return springs on the rear brakes were hitting the rotors making an awful screeching noise even though they still had about 60% of the pad left, failed navigation module, lower seat cushion would shift during turns and make a clicking sound,  last but not least the paint was peeling off of the rear drivers side door due to bad prep, you could see the imperfections in the primer coat that were causing bubbles in the base coat.  Enough was finally enough and I decided I was trading out regardless of the financial hit.  Turns out I got a trade offer that was beyond my wildest dreams and jumped ship to a competitor (I'm intentionally not mentioning the brand to spare the haters the need to mention all the issues I'm going to have with  __________ <---enter brand here) because they know a guy that bought one and the truck went rogue and castrated him in his sleep, then murdered his family exploded and burned the whole house to the ground.  The fact of the matter all mfg's have their issues and all have their fanbois that will defend their brand to the death.  I'll take my chances with another manufacture having issues and trying to fix them versus giving GM my money and having an issue that they haven't corrected in 5 years of production and barely acknowledge.  Loyalty is earned not given and GM has done nothing in its history to earn anyone's loyalty, the few on here who have gotten buy backs had to fight tooth and nail to get them and even then GM tried to screw them.
To anyone reading this that has the dreaded shake.  I feel for you and if you find yourself driving at those speeds often ask yourself what your sanity is worth and just dump the POS if you can with the new GM platform out now you can bet there is no attention being paid to this issue from GM.  Their customer care hotline is a joke don't waste your time, I was told they were working on it an anticipated a fix in a few months, over 3 years later and nothing.
Off topic a bit;  but, I’ll post anyway.  Apparently, Trump is going to allow E15 gas to be sold everywhere.   Wondering how this will affect 6.2L engines.  I believe they’re only rated for E10 gas.
Brianibew - yes my is Duramax Denali HD which is same as Duramax 2500 HD. I did see that Sierra 1500s was the trucks mostly affected but after I watched a you tube video of a post with 1500 Sierra and bottle of water shaking in center counsel, I started getting nervous about my truck, however, I had since tested a bottle and sunglasses in my and there is nothing compared to what I saw in you tube video post. My is generally coming from rear end and I still feel just poor balancing and/or the fact that lots have posted about goodyear wranglers not being able to road force balance. I just got 1100 miles on the truck and will continue to monitor but since dealership let out some air from rear tires it definitely changed the shake/vibration and it’s less now. So I would like to find out others that may have had similar case but strictly with sierra 2500/denali HDs not 1500s. Thanks!
Yep saw this video and my doesn’t do the same when having a bottle of water in front center console. Again it would be cool to get in a truck that also vibrates to really compare and determine ifan issue exists.
Very happy to report I received a call from the service manager today, they really did send the data to GM and GM told them to go ahead and replace the Ring and Pinion in the rear end. He said they should order and have the parts in and installed by early next week. This is great news and means they are still actively chasing the trouble. Way to go! my Chevy Dealer for keeping the promise of correcting this issue. I really hope this corrects it!
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
