Slick66 Posted June 7, 2019 Posted June 7, 2019 Looks good. It’s a shame that we truck lovers have to go through so much these days just to make our 4 wheel drive trucks look like 4 wheel drive trucks! 2
Racindave Posted June 8, 2019 Posted June 8, 2019 (edited) Mines 2wd but just put a 1.5 inch level on the front. Rear is stock. Gonna go with bigger tires when these wear out. I’m satisfied with the level because i still wanted some rake with towing. No difference in ride. Edited June 17, 2019 by Racindave 1
theJman Posted June 8, 2019 Posted June 8, 2019 On 6/7/2019 at 3:31 PM, Slick66 said: Looks good. It’s a shame that we truck lovers have to go through so much these days just to make our 4 wheel drive trucks look like 4 wheel drive trucks! Seems like it's mostly GM that doesn't get it, the HD trucks from other manufacturers look the part.
Racindave Posted June 10, 2019 Posted June 10, 2019 (edited) On 6/8/2019 at 6:23 AM, Racindave said: Mines 2wd but just put a 1.5 inch level on the front. Rear is stock. Gonna go with bigger tires when these wear out. I’m satisfied with the level because i still wanted some take with towing. No difference in ride. Truck on left is stock same exact model Edited June 10, 2019 by Racindave
amxguy1970 Posted June 10, 2019 Posted June 10, 2019 On 6/7/2019 at 2:31 PM, Slick66 said: Looks good. It’s a shame that we truck lovers have to go through so much these days just to make our 4 wheel drive trucks look like 4 wheel drive trucks! Yup, because image is very important; you have to have others know you drive a 4wd truck regardless if it is used or not. It can be easily rectified by placing strategic 4wd emblems/stickers on the truck to let others know you aren't driving around in a lesser much less macho 2wd truck at the local starbucks... Tyler 1
Schmiesus Posted June 13, 2019 Posted June 13, 2019 3" Front 1.5" Rear TRUXXX kit no rubbing with a 275/60R20 Ko2 with 20x9 0mm Wheels
BugzzyZ71 Posted June 18, 2019 Posted June 18, 2019 Eibach pro truck kit 2.5 front / stock rear height 33X12.50R22 atturo trail blade MT so far I’m loving the suspension & tires ! 3
MrT1106 Posted June 21, 2019 Posted June 21, 2019 On 6/13/2019 at 4:08 PM, Schmiesus said: 3" Front 1.5" Rear TRUXXX kit no rubbing with a 275/60R20 Ko2 with 20x9 0mm Wheels on the rear kit, how did the ubolts fit over the leaf springs? did the centers of the ubolts sit flat against the leafspring?
Schmiesus Posted June 21, 2019 Posted June 21, 2019 46 minutes ago, MrT1106 said: on the rear kit, how did the ubolts fit over the leaf springs? did the centers of the ubolts sit flat against the leafspring?
DENALIHD66 Posted June 23, 2019 Posted June 23, 2019 Added Bilstein 5100s on highest setting and Toyo Open Country AT 2 at 295/55/20. Ride is NIGHT AND DAY different from the OEM "Max trailering" shocks. They were basically shot at only 42,000 miles. Tires rub the sway bar on BOTH sides when moving forward... rubbing seems to begin before full lock so I've had to adjust my driving habits just a bit. It makes me wonder if 285/60/20 would fit without rubbing?
