1.5" motofab up front
2" motofab rear block (1" lift)
275 60 20 Cooper at3 4s
Has 28mm bora spacers due to level causing uca rub.
After going to 33" tires had to trim aftermarket mud flaps and zip tie wheel liner due to rub. 557376dfd579ef80f20e6843f8efa283.jpg
Sent from my SM-G960U1 using Tapatalk
Here’s to all y’all that said 285/70/18 would rub with a 2” RC leveling kit. Well I’m here to tell you they don’t but lord have mercy it’s close.
Dang, you really wanted everyone to see this by posting in 10 different threads!
Looks good -- nice and beefy, but your definition of "fit" might be limited to level straight pavement running.   At full lock with any kind of suspension compression, they are going to hit.  May just rub a little, or may catch the liner and start shredding it.    Looks like a tire more suited for a 4" lift than a level.    Glad you posted this because it confirms that my 285/65/R18s are the biggest I can run on my 2.5 level 2014 Sierra based on the way I use my truck.
Installing motofab 3” front and 2” rear leveling kit on 16 Sierra. I want to also add new UCA while I’m in there. Looking at motofab UCAs. What tire rim combo can I run without rubbing the UCAs. Buying 20x9 rims just need to know offset that will clear. I’m thinking +6 or less should be fine?
thanks
Edited by Built2crash
is that the front or rear?  have a hard time believing it wont rub at full lock...but if it doesnt and you can drive it, good on you.  little too close for my taste.
That’s the front at full lock to the left. Had these a couple weeks now and still no rub. Here’s a better view.
Anyone know what I can fit with a 2” RC Level in the front? I’d like 33x12.5x20 with a negative offset wheel. Pls help lol
I’ve posted elsewhere but figured it goes here as well. Fairly recently did a 2.25” level with 285/60r20 Toyo Open Country ATIIs and really like the look and the ride!
On 10/31/2019 at 10:32 PM, manderson7015 said:
It's a beautiful thing. Fronts are done. On to the rear.fa0111f4676afa1ccef9ae0594e175c8.jpg117533c5196c811a550f66d753405e84.jpg
I liked this setup and ordered it, minus the UCAS, yesterday.  Trying to decide if the control arms are necessary.
You'll have to cut inside fender well.
Sent from my SM-T580 using Tapatalk
Not necessary but when i go 1" higher in the summer i will not have to change my uca's. I was proactive when i did this. Still liking my set up.
Thanks for the follow up. That’s good to hear. My kit should be here today and I’ll install it tomorrow.
Not sure if this is the right place to post, but I have a 2018 GMC Sierra All Terrain. I want to get a level completely on the truck and remove the rake. I also want to fit some 33.5’s-34’s by 11-11.5 wide tires and still keep good or better ride quality. I’m thinking of keeping my stock 20’s or possibly later get some Method 17’s. What are some good options for a daily driver such as myself. Not looking to rock crawl. Can I just put some Bilstein 5100’s in the front and remove the rear block? Any help would be appreciated. If this has been answered before I apologize but 250 pages is a lot to look at! Thank you!
Edited by Danyoda
    juggernautusa
    juggernautusa
  • Who's Online   2 Members, 0 Anonymous, 501 Guests (See full list)
