On 9/2/2019 at 8:14 PM, Yondu said:
Thanks for the info. Someone had said they are both straight through, so I wasn't sure what a new muffler would do.
I'm considering replacing the muffler and flapper with the Magnaflow 12589.  22" muffler.  And leaving the stock resonator.
If like to keep the v4 mode though and have it setup to only be active above 60mph, for free way cruising.
My 6.2L has slightly larger pipe than 5.3L. I have the 22" 14909 100% stainless maganaflow (12909 is stainless internals and anti corrosion coated outside.)
I had the flapper cut out and left the resonator. Honestly it sounds stock in the cab until after 3k rpm or more than half throttle. Then it sounds deeper than stock and some growl. I still use V4 around town sometimes and you can defiantly tell when its in V4. On highway cruising its hard to tell when in V4. Not bad like some that have deleted muffler or gone with aggressive flowmaster and they get the helicopter noise.
I would still do this mod again even though it is a quiet muffler. I like the flow through design, and getting rid of the flapper. From the outside of truck it sounds badass when I have a buddy stomp it and drive by, from in the cab it sounds a little more aggressive than stock but not night and day.
For the $170 (stainless magnaflow on ebay) + $80 for shop to weld in it was a cheap mod as far as exhausts go.
That's some really good info, sounds like exactly what I want.  I'm glad to hear highway cruising is much better for v4 than city.
Thank you.
@Yondu go for the Magnaflow 12589.  Sounds like you will be pleased with the sound.  I've had the 12909 on my 2015 6.2 AT for 4+ years and like it.  Not too loud or droney even when towing a trailer.  Cold starts are louder than stock but the neighbors won't be annoyed with you.  Nice deep, mellow tone and lets you know a V8 is under the hood when you gas it.  At cruising speed on the highway 60+ mph drone and V4 chop is minimal even without the flapper valve.  (Kept stock resonator)
Around town I manually put the truck in 7th so that V4 mode is disabled.
I ordered the muffler through Advance Auto using a 20% off coupon.  Including installation the muffler was $155 or so.  Look for a reputable exhaust shop who will carefully measure the stock muffler and flapper valve and cut them off precisely.  Welding up the Magnaflow shouldn't be an issue if they know what they are doing.  Good luck.
Hi guys! I just got my new truck and been doing a ton of research. I want to do a whole new exhaust system from long tube headers / high flow cats / true dual system w/ X-Pipe / 3" pipe and have it come out the passenger side right before the rear wheel. I was hoping I could get some suggestions cause the only kit I've been able to find is this one and this one from Stainless Works. This kit just seems way to expensive for what you get.
2017 GMC Sierra 5.3L SLE Crew Cab
Go with Speed Engineering long tube headers, Speed Engineering x pipe kit for trucks and run whatever mufflers you want and have the exhaust shop run tips before tire. I'm about to do the same and ditch the y pipe
Awhile back I went with a Flowmaster 50 with dual pipes out the back left the flapper. Got tired of the loudness and tried the 24” Magnaflow. It was still too loud (I guess I’m getting older). We put a 18” glass pack (straight thru) in front of the flapper after the cats, and after the flex pipe....sound is about perfect now. My question is to u experts. Do you think adding the glass pack that close will do any long term harm? Just FYI:  I would say the mangaflow felt better on performance than the Flowmaster, but the mangaflow was louder also.
Edited by Racindave
5.3 L83 Silverado
-Speed Engineering Long Tube Headers
-3" X-Pipe
-Twin Magnapack Magnaflow Mufflers
-Full 3" Exhaust
Here is the Video:
Edited by VdellaV
Is there any kind of resource (maybe a YouTube channel or something) that has videos comparing sounds of different exhaust systems?  I just bought a '16 Silverado 1500 5.3. I'd like to replace the stock exhaust for something with a little bit rumble but it is what we'll be taking on vacations and toting the family around in so I don't want anything too loud. Also have some concerns after reading about the 'helicopter' sound in v4 mode, which I have no idea what that sounds like.
Also, do you have to do anything with re-jetting or programming the fuel injectors or anything after switching muffler/exhaust?
Lots of YouTube videos out there with about every set up you can think of. If you’re wanting to replace the entire cat back, I would look at Corsa, Borla, or Magnaflow. The Borla and Corsa systems are a little pricey but hard to beat on build quality. Corsa is going to be a little loud but the good thing about their systems is no drone in the cab. Borla has several different sound options from their Touring, S-Type and the loudest being the Atak. Tuning is not really required for an exhaust system unless you’re putting longtubes on. A good tune can make the truck much more enjoyable to drive even with no mods. I would steer clear of that if you have any concerns with voiding your warranty. That’s a whole other conversation.
Look up Matt Earle on YouTube. He has several sound clips of about 20 different mufflers he’s ran. Most of his videos are with Kooks headers installed but it will give you a good idea of what options are out there.
Will those systems still pass standard emissions tests?
I'd check with your local emissions laws. I'm in California and you'll pass emissions as long as you dont mess with headers and leave all catalytic converters in.
Also the v4 helicopter noise is exactly that, imagine that a helicopter is following you.
All catback exhaust systems will pass emissions I would think since you are keeping the stock catalytic converters in place. You can even gut or remove the large round third cat and pass if you don't live in California from what I've heard.
I believe it is only there for California as many call it the California Cat but it is always good to check your state laws as stated above if you're concerned about being checked.
If you go far enough back on my YouTube channel (Matt Earle) you should find almost a dozen or more different mufflers I tried with the stock exhaust manifolds and all three catalytic converters in tact. I later added headers and shot videos of each of those mufflers over again and then tried more. It was a disease I think I may have finally cured but hopefully it helps people out.
Your videos helped me out a ton. I always refer people to your YouTube channel when they’re searching for exhaust.
I think most know of Kinney’s Muffler Shop in Texas however if not check out the link below. In my opinion they set the bar for custom exhaust systems with many videos to see and hear different combinations on a wide range of vehicles. If I remember click the ”videos” link on home page and it brings you to their YouTube channel.
http://www.kinneysmufflershop.com/kinneysmufflershop.com/HOME.html
I’ve been using Auto Pro in Conroe TX for 40 years for exhaust and modifications. Local dealers use Joey for custom exhaust work. I’ve dreamed up pretty wild exhaust over the years. He had no problems building them. He kept some of my custom cars going when I was too busy to do it. He’s the reason I couldn’t understand why people would buy mail order exhaust. Good to be spoiled.
    • Hi all,   I just bought a 2021 suburban RST with 88,000 miles on it and everything has been good but I’ve been noticing within the last month or so that there are small electrical things going on and I know what the AGM batteries and all the electric electrical in these big trucks you need to have a constant flow with good voltage   That being said, I bought a new battery thinking that that might have something to do with it but today I went to get in and start it and it said no key found when I had the key right in my pocket   It also proceeded to flash the lights inside and outside for over 30 minutes as I went to disconnect the battery as soon as I touch the negative terminal, I heard the relay reset and everything come back up. I got in the truck and started it no problem.   Anyone else have this happen to them? I’m starting to think it’s the KARR system that the dealer installed short circuit stuff.
    • I don't drive this truck on a regular basis since I have a new company truck with no out of pocket fuel or maintenance cost. Yesterday I got it out to run some errands and got the title message on my DCI. A quick Google search suggested to first clean the Map Sensor. I pulled it out and it was sooty so cleaned it up and reinstalled it. Issue not resolved. My OBDII is a couple years old so didn't see any codes. Today I took it to a friend at AutoZone to get him to check it with his reader. It had the following codes: P20C3 P02BB P221F Stating the most likely solution is to replace diesel emission fluid (DEF) tank assembly.   So, I guess a trip to the dealer is necessary. I read where there was a backorder on these tank assemblies several years ago so hope that has been resolved.
    • Are you using a weight distribution hitch system with your trailer as that alone can change the actual tire pressure requirements needed. It would prove interesting to see what the actual individual axle weights are on your truck when you are hooked up to the trailer. In fact when your hooked to the trailer, typically if anything unless it has a large capacity weight distribution system that is over cranked, often the weight on the front axle will be less when hooked up vs driving empty and certainly if one doesn't have a weight distribution hitch. Really the only times one may get up there with weight on the steer axle is if there was a snow plow mounted on the front or a motorcycle on a rack or with a very large jockey tank full of fuel at the front of the box that transfers a bit of its weight to the front axle.    And of course your tires carry more weight for a given tire pressure due to their size vs a stock sized tire so there is that to take into the equation as well.
    • Great info here thank you. I just joined, we have a 2014 Silverado truck we bought about 4 years ago with less than 5,000 miles on it. It has approximately 24,000 on it now. It appears to have all the standard issues that people are talking about. Occasional charging problems especially using 110 volt, occasional blinking triangle where nothing will turn on when first starting the truck but it will reset itself if you wait 10 to 15 minutes. Noisy coupler between the flywheel and the generator. Our truck is speed limited to 74 mph, is there any way to change that? The latest issue we have been dealing with is when driving long distance on the highway at full speed the generator does not keep the batteries charged. The meter will go into the yellow/red border Zone for charge status and the yellow triangle will illuminate solid but the generator will not keep the battery charged, not sure why the controller doesn't tell the gas engine to increase RPM to increase generator output it usually stays well below 25 kilowatts even though the battery is discharging and I have to slow down the highway to 45 mph and eventually pull over and let the truck idle to charge the battery so I can continue driving at speed. Has anyone had this issue before or have any idea how to diagnosed it? When via Motors was around it they were very helpful at troubleshooting. This becomes much if the Terrain is hilly and you're towing a small trailer
    • I have the GMC accessory (REV) cover installed by dealer. Ordered with the truck.  They did a very good install job, can't find a single issue. Some water gets in around the tailgate but no where else.  You can see daylight around the tailgate but that's not the covers fault.  Installation is means everything. Guys at my dealer were seasoned pros, not inexperienced here today good tomorrow types, like many dealers employ for these jobs.   I don't mind paying for a professional job.
