3 hours ago, bkesting said:
Where did you get that bed fence?
from my garage  :D
see this post from page 871 of this thread....  box divider
2 hours ago, bc-chris said:
from my garage  :D
Got it. Looks great and OEM to me. Good job!
Yesterday I installed the Belltech lowering shackles to lower the rear end a total of 2". Filled up the wheel well nice with the Chevy 22's. Today. I was in the market for a Quick Detailer and after much reading, I went with the Griot's Garage Best of Show detailer. Bottle claimed it could be used in direct sunlight but I found it hard to remove. Switched to a shade spot and was much happier. Added depth to the tintcoat and looked great.
Nothing to show for it yet but finally pulled the trigger on a diamondback tonneau cover. Was back and forth between the cover and a cap for a while but in the end the lower cost, higher durability and "truck look" of the tonneau won me over.
Confirmation said I should be receiving is in 3-4 weeks. Fingers crossed it's sooner. Also have some other mods I've done that I haven't yet posted. This weekend shes getting detailed and 2 more tiny mods and I'll upload some pics.
Got a call the other day from CHP, my truck is officially released from impound and is property of Antelope Valley Towing, in Palmdale.  If you want any parts off of my ‘15 Silverado LTZ Z71, you will have to get with AV Towing.
All of my personal property is removed, CB, scanner, CB Antenna, phone holder,, CDs, etc.
Nothing today but installed my AFE gt momentun last week. Nice little sound and "mine is different from yours" effect ?. Dont really care about any claim of added HP, I just like doing little mods
Swapped out the jump seat last night and installed an '18 console. Thanks to pgamboa for making the harness!! Side note, I have a never sat in jump seat for sale now central Texas area ha
Was able to clay bar and carnuba half the truck last night. Loooong overdue!! Looks so good.6111c240872c2203d2f33bc3e4a32586.jpg
1 hour ago, CajunFries said:
Gonna try to make the bracket at work one of these days.
Gonna wait for this one, good luck, hope it works out.
Where is the cheapest place to get the driver side grab handle kit for the A-pillar?
(Late to reading posts from last week so sorry if someone answered) I ordered mine off one of the gym outlet stores. Kinda just looked up the part # and found cheapest price
Keep us updated please. Been trying to add fogs but between buying a new bumper (I don’t have the holes) and the oem set. It’s wicked expensive where I’ve debated on aftermarket
On 5/21/2018 at 3:15 PM, pgamboa said:
Which panels and in what order did you have to remove to add the knob? Going to have your same bass setup installed this weekend and I want to explain to the shop how to add the knob just to be on the same page. Thanks!
When I took that part off to add light switches, I took off the panel that is “touching” the door as the door is shut. Then I went from the top and bottom and popped them out. I don’t believe it’ll be much different with yours even though you have the brake controller. It should have enough slack to pull out just enough to disconnect so you/they can make the hole.
Great thanks! I actually don't have the brake controller sorry forgot to mention that. I have the pocket there.
So the entire aluminum/plastic piece comes off first, then you can remove the black piece?
