28 minutes ago, bayouguy71 said:
It is definitely a different shade of black than the plastic panels but still looks good.
You should buy the leather stitched shifter instead of the glove boxes
I'm actually starting to like this stuff. Its water based. Shiny as armor all extreme. Armor All Extreme is solvent based.
There has been a debate about this topic on an RV forum I visit.
The debate was will tire dressings extend tire life. Most RV tires are date expired long before the tread is shot. Sidewall cracking is common.
I'm on the fence. The actual idea of a solvent based anything on my tires don't sound like a great idea but who knows I've been using armor all since it first came out, when in the 80's?
I've used them all and I like this Lucas stuff right now. ac633d37bf169de9981e30d5e8de7e9d.jpg
Sent from my Pixel 3 using Tapatalk
Does it wipe off the wheels easily if you get overspray on them while doing the tires?
Yes. Wipes off real easy.
It slings a little less than the armor all extreme too.
I think if you hit it with a clean dry rag it wouldn't sling at all.
 I will have to try to find one of those.
1 minute ago, Frankielozano214 said:
It’s a nice easy upgrade,
Happen to know the p/n for black?
Does it matter if I have the 6spd?
Got a killer deal on some brand new OEM wheelhouse liners with hardware.
I’ll have to check on the part number, but shouldn’t matter what trans u have.
Shift Lever 22857352 1 $68.04, should work with your truck no problem.
Never tried this one but my go-to has always been Adam's Tire Armor after using tire and wheel cleaner.
Edited by xSHIFTxNASTYx
Installed a Rough Country low profile tri-fold bedcover this past weekend. I’ve heard this is just a rebranded Gator FX bedcover but all in all I’m very happy with it. Seems to be very well built and is great alternative to similar $1000 covers. Now if only my tailgate locked with the key fob. I don’t not think GM started that till 2016.
1 hour ago, boettcher40 said:
Check out Pop & Lock. Easy installation, only need to tap into two wires underneath the drivers side door sill. Installed mine back in January with no issues!
https://www.amazon.com/gp/product/B00JM208IG/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
What year is your truck? i think ima do this I was gonna buy a newer taillights 2016+ but if it’s possible to add this like factory style I’ll rather just do this.
2014. You retain the factory key lock as well, on youtube there are some installation videos and reviews
I still haven't done this upgrade.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
