Got around to pulling all the parts out to make sure I have everything. The engine should be out tomorrow and hopefully new parts will start going in.
quick parts list
-L86 manifold with additional port injections. (will be installed with 50lbs injectors but won’t be hooked up just yet)
- 2000cc meth injection
- Borg S476 with billet wheel
- Cam Motion turbo cam
- BTR .660 dual valve spring
- Johnson 2110R lifters
- CHE trunnions
- Turbo Smart WG / BOV
- ARP head and main studs
- L86 OEM crank
- GPI “drop in” pistons and rods
- OEM head gaskets
- custom Garrett core intercooler
- Derale trans cooler (will be under the bed). Removing the 40k Trucool from up front.
And a bunch of other little stuff.
Edited by CajunFries
  • Like 4
1500 PAGES?!!!!!  HOLY CRAP!!!!
Drove my truck for the first time in 10 days, $8/gal sucks, been driving my son's car or my wife's CR-V Hybrid, and driving my truck once every week or two.  As I was driving down the main drag in town, I heard something flopping in the breeze under my (open) sunroof.  I usually drive for about 10 minutes or miles with the sunroof in vent and shade almost closed, to draw the heat out.
Found it to be a VERY simple fix.  Just re-engage the clip/slot from the front to the back.
Edited by Ravenkeeper
$8/gal?!?!? Where are you at?!???
I removed the plastic fender pieces and pulled the wheel well insert. Gave everything a good cleaning, then re-installed.
Super easy to do, don't need to remove the wheel. Just a T15 bit and a phillips screwdriver.
finally received the builtright bedside rack, I'm 2 days into a rather mean cold that has me wore out, I will try and piece it together in the next couple days
Ok, I exaggerated a little bit.  Average price around Antelope Valley (Lancaster/Palmdale) is $6.75
Ahhh gotcha. I havnt been out there in a while. Used to ride at willow spring all the time.
10ft of heat sleeve for the AC lines and couple of wires and Heat shield for the battery trying to protect it from the heat from the turbo. 35D83E49-FC03-403F-81B9-2F4ED8B52782.thumb.jpeg.9b3e265033247dd0d6266fe5eac62bb3.jpeg
I am definately going to do this for my 18.
Finally got a chance to test out my new electric pressure washer and foam cannon. Was too into the wash I forgot to take a picture of it all foamed up. Clayed/waxed after the hard winter neglect, full interior detail as well. Much needed!
Next week going to drop the trans pan and change filter/oil. 48k since the last time it's been changed and shifts are starting to firm up more than I'd like. Hoping to get as much life out of this 6 speed before I start getting the itch for a new AT4...
  • Like 5
What have I done for my K2 today. Well great question. I ended up finding a torn CV boot. Now researching my options.
  • Sad 1
Insulated the doors with ccf and ccf/al. Sounds better for sure. Now to chase down a door panel rattle.
Edited by Snowcamo
  • Like 5
finally got around to getting the builtright bedside rack system together.
comes with absolutely ZERO instructions, not a big deal but assembling some of the quickgrip stuff it would be nice to have a general idea of how it is supposed to be, there website has some install guides but none for chevy
I have a bedliner installed so it has complicated things a little bit, the bottom attachment is not ideal it is a U shaped bracket but should be a u-bolt or a j bolt or at least have a L leg so you can turn it and snug it up that way, the way it is it now it just binds up so I bought some longer bolts and sleeves at the hardware and will finish it up in the morning.  I may end getting a u-bolt and drilling a couple holes in the rack I could not find one that would fit the existing holes
  • Like 6
Had my passenger side rip late last year. Easiest and quickest option IMO... replace it. Took me about an hour, worst part is getting the dang thing out! Ended up having to remove the bottom 2 strut bolts, and sway bar end link which gives you some additional room with the lower control arm dropped.
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
