When I installed my 5100s on the highest setting my toe was all out of wack.  I later installed a 1/4" spacer under the strut to get a little more lift and tow changed again but it was barley outside the factory range.  I got it aligned to bring it back within spec.
On 2/28/2019 at 11:12 PM, Yondu said:
They have been coming soon for 5 years.  We have had a part number for like 6 months, IIRC.  I called Bilstein a few days ago and they said very soon.
Minds will be blown if/when they actually come out
Did Bilstein offer any specifics or did they just say "very soon"?
On ‎2‎/‎28‎/‎2019 at 9:05 PM, bhales said:
so what am i missing about this part number for the 6112:D:smash:other than the fact no one seems to have ever had them instock. i went over some railroad tracks today and i thought i was gonna die the ranchos SUCK.
Ahhh, the infamous Bilstein 6112 shocks for our 2014 and up K2's
You will have better luck trapping a Sasquatch or sitting down to dinner with an Alien !
Most of us gave up on the 6112's years ago since their first reported introduction back in 2015.
Yes, Ranchos SUCK on railroad crossings and potholes.
Funny thing is, the 6112's are currently in stock for 2015 and up Tahoes and Yukons.
Many wonder if you can just order a set for the Tahoe/ Yukon and bolt them up to our K2s......
The GM parts sites list Silverado, Sierra, Tahoe, Yukon as fitment for the same spring & strut part numbers so wouldn't aftermarket be the same situation?
Sent from my Moto Z2 Play using Tapatalk
When I pressed for more information he said should be within the next few months, keep checking our site.
I'm not sure what the difference is between the Tahoe Yukon and Silverado Sierra are. It's very interesting they would release the SUV parts first as I would think there's more of a demand for the trucks.
At the price the Tahoe / Yukon 6112s are I would have expected a threaded body for adjustment on the truck & a decent top mount, not re-using the stock rubber stuff.
If you want threaded adjustment you are going to have to tap into the Coil-Over market and pay nearly double.
The point was, the aren't being used as a stopper, it's already sitting on them.
Going back to this bump stop situation, did you find anything else in this regard?
I had about 2" of travel showing between the shock & bump stop when it was assembled but no weight on it. I don't know how much the truck compresses this but I doubt there is much stroke left before the bump stop is contacted.
This might be part of the problem with the OEM shocks, allowing the suspension to bottom out easily & bounce off the bump stops.
I will try to see if I can check the gap to bump stop with the truck on the ground.
Ok, after typing the above, curiosity got the better of me. I cannot get the dust boot out of the way enough for a photo but it absolutely feels like the bump stop is sitting on top of the shock body & I can't move it up with my fingers.
Next step will be to take the weight off & see how much the suspension compresses with the truck weight.
If this setup really is allowing the bump stop to be partially compressed most of the time that seems very strange.
Mine is the same way.  I can't imagine it's any different stock, but I never checked.
Does this all suggest that they would ride better at 2nd or 3rd height setting rather than the first?
Mine is at 2nd stop, but yes that would make sense.
My guess is stock shock is most likely worse as it has softer damping so compressing bump stop more when hitting a bump in the road.
I'm at 1.4 lift, 2nd to top.  I assume the truck would ride after if the bump stop were trimmed.
    • I did shorter OCI"s for many years without an issue, fights sludge and wear IMO. Recently started using Amsoil, will not do the recommended/advertised miles between changes.
    • It definitely seems quite evident that emissions and fuel economy targets rule above the best case scenario of what the engines best health and life could be otherwise. Items like DI and turbo DI engines with their LSPI issues as well as cats being reduced in life if the proper levels of certain additives were allowed to be utilized and so something has to be compromised and as you point out that is the engine protection from sludge, acid and wear which isn't in the manufactures best interest regardless to worry about in this race to profits from higher sales and so if the engines wear out sooner the next sale is closer at hand.    I am hearing that its likely the two new 2027 GM half ton truck engines will call for a 0W-30 oil, now if that is an existing oil I would have to think so but we will see in the coming months. Sadly as you've pointed out to me, over the last number of years the push has been on to reduce the actual operating temperature viscosity within each designated viscosity grade so that 11.5 to 12 range for a 30 weight for example is more in that just above 10 range at 100c along with that temporary viscosity sheer dropping it even further down as per that "energy conserving" designation, not to mention how some oils are not as sheer stable as would be ideal and that mixed with a long OCI paints a picture with a little too much glitter shall we say !.    All that and the warranty gods scaring the vehicle owner into sticking with that watery wine or risk loosing their warranty coverage if they go and use an oil that is of a higher viscosity even if it meets the emissions and LSPI requirements and would never damage the engine but may very well allow for an engines longer life depending on engine use scenarios ... high ambient temps, towing etc that push oils to their limits.
    • Very true.   However.  GM did give those trucks with the single speed case Terrain Mode.  Terrain Mode mimics 4LO minus the gear reduction and torque capability.  It uses the ABS/braking system to perform the operation.  It also gives these one pedal driving (sort of) when in Terrain Mode via the active brake during throttle lift.     Does it have its limitations over a true 2 speed case?  Sure.  But it works.
    • Of course actually engaging four wheel drive is step one or even daring to use a ramp like that with a two wheel drive and getting into a mess because of it. As to 4 low, these last few years if its a GM half ton it may not even have low range. A lot of the newer pickups have a lot lower first gear in an automatic transmission then they once did as it was common at one time for a gas engine truck or even the older diesels to just sit there and bog the engine due to the torque converter stall point and not enough torque was generated on reasonable traction to even spin a tire or get out of its own way up a steep grade and 4 low HAD to be used to get enough power to four tires to get them turning. These days traction control systems may hinder a vehicle in a situation like that although that means a tire or tires are spinning so in some ways the traction control can reduce wild spinning and anyone can correct me on that but I think some vehicles cut traction control off in low range ?.    By the sounds of it and you may have the proper equipment but if your responsible for helping vehicles out if they are not able to get out under their own power, I would say to be using a nylon tow rope or have one available so that one is able to give a bit of a run to help sling shot them some initial momentum as most tow straps are made out of polypropylene and impart way too much shock load if used to jerk a stuck vehicle into motion but are totally fine to use if going more from almost a dead pull with the tow vehicle and they are a lot less expensive to replace if damaged. That and some soft shackles to hook onto closed loop tow hooks on the truck your pulling as well as you having the proper shackle insert in your truck so there are no bad accidents with metal clevises joining things together or chain on the end of a tow rope or tow balls being hooked onto etc flying and causing damage or worse if it lets go. Its always a challenge pulling people because some are clueless and will over run the tow rope or strap and drive over it or that risk of ramming into the back of the tow vehicle so usually a few instructions are needed to clue in the driver of the stuck truck. Yeah ... have fun out there 😉
