Question for the brain trust.
New 2018 Silverado 1500 short bed single cab 4x4 LT Z71 with the Ranchos. 3000 miles on vehicle.
I just skimmed thru the 130 pages - this may have been answered before. I don't like the way the truck handles. Boingo boingo pogoing in the front. Feels over sprung and under damped. I do not desire leveling or lowering, just a more planted feel. Would the 5100's set at 0 leveling give be a more stable, road-holding feel?
Any input greatly appreciated.
Edited by Bill Hammer
Hi,
I had read almost everything there was on here, recently installed 5100s all round on a 2014 with Z85 suspension code (towing package I think).
My biggest complaint against the OEM from new was the rebound after a sizeable bump or compression. After a fairly sharp speed bump at quite low speed it felt like the tyres would bounce of the speed bump, then slam into the road, sometimes enough to bounce back up again.
The Bilsteins on the second from lowest setting have improved things a huge amount, speed bumps can be driven over just like every other vehicle I've owned.
The only harsher characteristic I have is the smallest road imperfections (joints in road, tiny holes) are slightly more noticeable.
I only wish I'd swapped years ago.
You can get better, even more compliant systems for a chunk more cash or you can look at the Eibach which is a similar setup.
If you definitely don't ever want to level then you can order the 4600 Bilsteins for less money & the same performance AFAIK.
Sent from my Moto Z2 Play using Tapatalk
Do a search for Bilstein 4600 and for Bilstein 4600 vs 5100, both here and Google. I think you'll find it's basically the same shock made for stock height with no adjustment. It will save you some money if you don't plan to level or lift.
I have not used Bilstein, but have researched it and this is based on what I've read here and other places.
You can still use the 5100 with a desired "0" inches of lift.
4600's are Yellow, 5100's are the machined silver appearance. Go for the look/color you want.
To answer your question... Yes and Yes. No more Pogo Stick. 5100/4600s will give you a planted feeling and eliminate the jarring response of potholes etc.
Where are you getting these pics?  I see they're on Bilstein.com now but I can't find what you posted.  Do they list the spring rates? When I called Bilstein last they didn't have that info.
15 hours ago, cokedrvrbjw said:
Probably just going with the following, it’s like waiting for my wife to finally put out....
New side piece
I think you could buy this piece by piece and save a pretty good amount.
On 3/19/2019 at 8:01 AM, bhales said:
Can you share actual links? I was just searching yesterday and found nothing.
Downsouth Motorsports has these. The cost though for a non coilover seems a bit pricey.
I asked about them a while ago. They aren’t super popular around here because of the cost
The 6112 was avail in 2016ish I believe.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
