1 minute ago, Sierra Dan said:
Has anyone seen these? About $1300 for a set of four and seem beefier than 5100's
See the source image
Yes, I looked at these but could not justify their price.  $350 for a set of 5100s vs these at $1300 doesn't make any sense.  You can get HaloLifts Boss coilovers for the same price.
https://www.halolifts.com/HaloLifts-Boss-Ultimate-Kit-fits-your-2007-UP-GM-SilveradoSierra-1500_p_220.html
The Falcons are a beefier body and shaft compared to both the 5100s and HaloLifts you reference.
Falcons look similar to the 6112's. No spring of course but similar body diameter.
Anyone receive or install 6112’s on their K2 yet? I am interested in a set but would like someone to be the guinea pig lol.
41 minutes ago, BbyDgital said:
I ordered mine first thing in the morning on 3/28 after seeing that they were in-stock and still don't have them.  I was curious if anyone has received theirs yet as well.
Thanks. Post an update once you get them. I’ve got 5100’s in the rear but still stock ranchos up front with a level. Would love to switch to 6112’s if there is a noticeable difference in ride quality.
After reading through 135 pages and entirely too many "where are the 6112's?"....I pulled the trigger on 5100's and installed on the 3rd setting and I'm very happy with the results.  I was hesitant of the highest setting, as I wanted a little bit of rake, and a slightly better ride (even if it's probably just psychological).
I ended up yielding 1.75" on the 3rd setting.  Perfect amount in my opinion. Truck looks damn near level to the eye.
Honestly in terms of ride quality, I can hardly tell any difference from stock on small sharp bumps cracks.  However just as everyone has claimed, the truck feels way more planted on larger hits/uneven roads.  Way less body roll and dive under braking.  And best of all, no more wallowing boat-like feel.
Wheels and Tires being installed as we speak.  Big thanks to this thread.
Thanks for pic....helps a bunch....definitely going with 5100s.....great review....take another pic with wheels and tires
On 4/10/2019 at 7:28 AM, huntr1117 said:
After the wheels are off you need to take out 2-10mm bolts that hold your brake line and abs line to the knuckle/uca. Then you're gonna have to remove sway bar end links on both sides to get the lower a-arms to drop. That should get you enough room.
Sent from my SM-G975U using Tapatalk
Exactly what you said. Took me about an hour, thanks??
Exactly what you said. Took me about an hour, thanks[emoji1360]
Awesome. Glad I could help.
I ordered 6112's beginning of this month along with 5100's for the rear, nothing has come in yet bet I will def update this thread once everything comes in and install.
6112's have to be better than the Rancho's, I will update this thread when I put mine on. I will be installing them on one below the top settings wise and will not use a spacer.
Anyone have pics or links to see the upper ball joint angle after install on the highest setting?
On 4/11/2019 at 12:06 AM, TheGreatOne said:
Any pics of how it came out?
Sorry. Didn't get them on last weekend. Doing the install this morning! I will post pics as soon as I can!
Thank you for the reply. Looking forward to your update, I plan on doing the same set up with the 6112’s
No problem.  Here's a pic:
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
