32 minutes ago, tkotx said:
Can I go Bilstein 5100's all around with 285/60/R20 on the factory 20's no rub?
I'm little confused. Shocks don't rub  If you're asking if that size tire will rub anything on the truck lifted at full height with stock wheels I would venture to say yes they might rub your stock control arms and felt wells at full cock??
You could possibly get some 1" or so wheel spacers to help them rub less or not at all.
Probably not very much help. Stock wheels are some unknowns with exactly how much backspacing they have as I can only answer my personal experience with my stock wheels.
We have no knowledge as none was given regarding your vehicle year make model pics of wheels, etc...
Good luck with your build
Well obviously I was speaking about tire size. I have a 2017 GMC Sierra 1500 4X4 with factory 20's. I'm going to put the Bilstein 5100's all the way around and put the front adjustable shocks on the third or 4th notch. The factory tires 275/55/R20 as ppl may know measure like 31.9 x 10.8. 285/60/R20 should measure abound   33.5 x 11.2.... I know from reading that 275/60/R20 will not rub and they measure 33" x 10.8"..... Just curious if anyone has put the 5100's on and used a 285/60/R20?
All I can add is my 275/60r20 did not run in 20x9 +24 offset, but there wasn't much room. I lifted the front 1.4", 1.85" lift will not have more clearance either.
They will definitely rub with 1" spacers as now I have 285/70r17 tires on 17x8.5 wheels, 0 offset and even though they're shorter (32.7 vs 33) they rubbed my mud flaps slightly until I trimmed them. No mud flaps would give me about .25" more clearance but I'm not going to run 0 offset wheels without them and throw rocks at my doors all day.
Finally got my truck done! 5100's all the way around and I ended up going 285/60/R20 which is 33.5" x 11.4" tire on the factory rim. There is a slight run at full tilt when making a u turn or cutting it real hard, other than that the truck rides great and looks great.
I got under the truck with my neighbor who is a mechanic and we don't think it's the ball joints. There is some motion in them but it's even on both sides and the noise only comes from the left. Also, when we lever the tire to check you can hear and feel a tap/clunk in the shock shaft.
I'm pretty satisfied that either the shock is damaged or the upper strut mount is. I can't get a hold of any of the upper mounts in under a week so this is on hold for now.
Sent from my SM-G892A using Tapatalk
Got done installing all 4 today and took it on a short test drive. The driver side front shock was shot and passenger was close behind.
After the work, the rattle is gone and it rides as well as I ever remember. The harshness I'd accumulated from the level kit, e-rated ko2s, and worn shocks is gone. We did put the extra spacer underneath and I'm happy so far. I'll report back if anything changes.
Thanks all. I should have gotten these from the start.
On 11/1/2019 at 11:50 PM, tkotx said:
IMG_6810.jpgYour truck looks great! What setting did you put the front shocks on. I have the same truck getting ready for tires and shocks but didn't want to raise the shocks all the way. What brand tire is that?
Hey Guys, I am looking to level my truck with 5100s all around, setting the front at the highest setting. Does anyone have pictures of the angles of everything after installing them? I had some issues on my old 2014 with just a 2.5" spacer kit and i want to make sure i avoid it going with these. Thanks in advance.
On 11/11/2019 at 6:34 PM, Jdub289f said:
Anybody got the 6112s now that they’re finally out?? I have the 5100s on my 2018 and I wonder if it would be worth it to make the switch.
They're out. People happy with them. Maybe worth it if you like to spend time in dirt.
Edited by Slash L86
Installed everything myself. These fronts were a b***h. Removed UCA, steering, sway bar, just to fit. Ball Joint was a pain to separate from the knuckle. But it's beautiful.
Discount Tire price match walmart for a good deal on 295 55 20
Rubs on full lock
5100s all around
Nice set up! Which height on the front did you do?
Highest level! 1.8"
    • No engine digit "E" for 2019-2026.  Stop reading slop online     All 2026 V8s have functioning DFM.  Hardware and software.  5.3 and 6.2.  The L84 5.3 has "D" as the 8th digit of the VIN, the L87 6.2 has "L" as the 8th digit of the VIN.       If you want a factory DFM disabled 2019-2026, you'd have to find a used 2021 or 2022 chip shortage truck.  The vehicle build data will have a specific RPO code indicating its a factory disabled truck.  RPO code YK9 and only with the L84 5.3 engine.  These still have the hardware installed but are NOT functioning due to the COVID chip shortages that were ongoing.
    • My post above is the direct reason for my outsized interest in keeping what I have for as long as possible. My memory isn't as short as some.
    • I don't think so. 😏 Cars? Our experience will diverge there as well. I was buying cars with 200K (1970's) when I started and quite a few were pretty solid cars. (My early stuff was 1964 to 1968)  Some stinkers but not the dismal picture painted above. Now that said, yes, a dealer wouldn't talk to you if your car had more than 60K on the clock and lot cars were 60K or less except the back row where 100-120K was the auction bought for dirt for us poor losers. Kids in my county were not allowed to wear long pants if they couldn't rebuild and repair every part of that beast.    I will agree that many parts are now better. Alternators and charging systems are an envy. But I replaced few water pumps or power steering pumps then. Rebuilt carburetors but replaced few. Mufflers are another place of OEM improvement. Stainless? We didn't have no stink'n stainless.    As long as humans are in charge of governance this $$$$ situation will not improve.    The purchasing power of a dollar in 1955 is significantly higher than in 2025, meaning that a dollar could buy more goods and services in 1955 compared to 2025 due to inflation over the years. For example, what you could buy for $1 in 1955 would require approximately $10.50 in 2025.  Calculator.net inflationtool.com   Comparison of Purchasing Power: 1955 vs 2025 The purchasing power of a dollar has changed significantly from 1955 to 2025 due to inflation. Below is a breakdown of how much more money is needed in 2025 to match the buying power of a dollar in 1955. Purchasing Power Overview Year Equivalent Value of $1 in 1955 1955 $1.00 2025 $10.50 Key Points Inflation Impact: The value of money decreases over time due to inflation, meaning that the same amount of money buys fewer goods and services in the future. Example of Inflation: What could be purchased for $1 in 1955 would require approximately $10.50 in 2025. This illustrates how inflation has eroded the purchasing power of the dollar over the decades. Understanding these changes in purchasing power is crucial for financial planning and assessing economic conditions over time.  Wikipedia Calculator.net
    • The thermometer has been in my wife's 2008 envoy, my sons 2016 chevy, my friends 2020 1500 silverado all showing cooler readings. It's not the guage.
    • Have a question concerning trim levels. Ive not bought a new vehicle since 2006, and I have decided on a 2500 gmc pro or silverado custom. For anyone that has one of these 2 trim levels have you regretted not stepping up to the LT or SLE. I look at things as the more electronics the more problems to arise. I love the look of the old school gauges on the dash as well. Looking forward to hearing your thoughts.
