Well I have a strut failure. I forget how long its been, but i posted here when I installed them. Passenger front is bouncing like the black factories used to. Drivers still functions as designed. Spoke with 4 wheel parts and they will have someone ride and verify and inspect. I'll pull it and have it swapped. Will update. They say it'll be covered under bilstein warranty.
I’m a little late to the party but after dealing with a slow leak on my truck I’m ready for new tires and a leveling kit but wanted to ask a couple tires. My truck is a 18 LT. I don’t go offroading I just want a little more clearance and bigger tire for northern MI winters. so I don’t need anything too hd which after reading seems like the 5100 will give me that along with a better ride. I know the fronts can go up to around 1.8”. Do the backs raise it at all? Or what do you guys use for the rear? Also where have you guys bought yours from I didn’t really see, the, on the bilstein website. Any input is appreciated. Also I read through a lot of the posts on here just looking for a little more info.
infound this which looks like the front adjustable plus a strut spacer and 1” rear lift. But I imagine it doesn’t ride as good as without the strut spacer.
https://socalsupertrucks.com/bilstein-leveling-2-5-lift-5100-shocks-2014-2018-silverado-sierra-1500/
and these from bilsteinlifts.com is that the actual bilstein website? It says the rear shocks are 0-1”. Is rear adjustable also or what brings the rear up.
https://www.bilsteinlifts.com/shop/chevy-gmc/silverado-1500/14-17-chevygmc-silverado-1500sierra-1500-4wd-bilstein-5100-0-1-8-front-0-1-rear-lift-shocks/
 Sorry for all the questions Im sure they have been answered but I can’t find them. Just want to make sure I buy the right part
Edited by 18LT
Hi 18LT,
The fronts are adjustable, the rears are not. Having said that, the rears a made so that the can withstand it if you did raise the rear about an extra inch. Typically, raising the rear of your truck would be don with blocks at the rear axle. A 1 inch block is really two inches. You remove the original one inch block that came with the truck and replace it with the 2 incher, giving you 1 inch of lift in the rear. I left my rear stock.
Regarding the fronts: only use the built in adjustments. Do not then also add a spacer to the fronts. I went with the highest setting and I think it looks good. Be aware that when you do that, sometimes the front might seem higher than the back. It isnt, but it might look like that to the eye. I added a leer cap to mine, that's almost a couple hundred pounds. If I then load the bed up with tools and camping gear, or some other heavy thing, it can sink down a bit and look a little foot-high. If you have the ability to, you may want to experiment putting it on the setting one down from the top, depending on what you like, and what you typically carry or tow.
I got mine from a dealer in the Jeep forums because I also have an old Grand Cherokee and I bought stuff for that through him. He will give you the best deal he can
His name is Nick, but he goes by Kolak.
Reach him at [email protected]
Tell him that the guy from Boston, who knows where he got "Kolak" from, sent you
Exercise. Extended length minus compressed length is stroke length. 50-60% of that number is a shocks designed static stance dimension. IF you do run this exercise on a stock shock you will find that you have 9 inches of stroke but measurement on the truck unloaded will reveal the shock is 3-1/2 inches ABOVE center! Why? Because the rear shock on a pickup is fitted to be in the 50-60% of stroke range when it is at it's maximum carry load. This also means the when the truck is empty there is nearly zero rebound stroke left.
They may allow an extra inch of ride height but will still be nearly topped out at rest and that extra length won't move the compression bumper any further away.
Hi Grumpy Bear
I have no reason to doubt your math and engineering on that. You do mention stock shocks, however. The Bilstein is a replacement to the stock shock, so I'm guessing it's designed with more stroke? They state it is designed for 0 to 1 inch of lift, so I can only presume that they have accounted for all of that?
4 minutes ago, ThundahBeagle said:
Hi Grumpy Bear
I encourage you to take or get the measurements. If you take them at their face value that would mean a shock with 5" or so more stroke. Is it? Is it really 5 inches longer that stock? Or is it a shock with 1" more stroke?
I use Kings on the rear of mine and they make the same claim but the truth is that shock is exactly the same length at the stock unit with the exact same measured stroke. 21" OAL.
Just say' n. Don't take my word, their word or anyone else. The measurements and math are to simple to get yourself.
For a guy who hauls allot of tows allot at or near maximums this matter not but if you run empty allot you can gain some rebound distance removing the factory block at minimum. It won't put you at center but it is an improvement you will notice on drop off's like pot holes.
I went with the 5100's on the 3rd notch, then replaced the factory Michelins with 265/70 Generals - so up a very slight 1/2" with the tires.  Nothing radical, but I like the look & road manners with this combo.
I went through a similar exercise of math when outfitting my rear axle.  I ended up using Monroe Load adjusting shock part#: 58640 vs the Chevy spec. part#: 58648
  The #58640 are actually spec. to a 2006 Dodge Ram.  Dimensions though, allowed darn near 2” additional up travel.  While only losing  about a 1/4” down travel.  The GM is 14mm eye compared to Dodge 9/16”
Bonus is, it lifted the rear about a 1” and firmed up the rear end.  I now have installed 2 other sets on fellow K2XX owners and so far so good.
Interesting. Does this make the back more smooth or just add more travel. How did you deal with mounting bolts? Thanks.
Sent from my LM-G820 using Tapatalk
The ride didn’t change much, a little less squat when loaded.  One of the sets that I installed were on my wife’s truck.  She didn’t notice a difference, in ride quality.
As for bolts, I used the factory bolts tighten to factory spec.  No noticeable play or unusual sounds.
Been trying to comb through this and utilize search function but..anyone with a 16-18 with stamped steel UCA’s running the 5100’s up front at settings 2, 3, or 4 and a stock 20 inch rim with a 33 inch tire (275/60/20 specifically) and have zero or minimal rubbing on UCA?  Having a hard time finding answers on this
I have this setup but I left the front shocks at stock setting and used a Rugged Off-road spacer.  This is on a 2018 Sierra Crew Cab.  No rubbing with the 275/60/20 BFG tires.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
    • So, lot's of googling and reading, and a trial fit found, that indeed they hit the newer fatter caliper. I did some re-testing today, and found just 3/16" worth of washers was enough for the wheel to spin freely. I added 2 more on each, and again it spun freely. Tested lock to lock with the 4 washers, about 5/16" not quite the 3/8" Im considering, but pretty close. No issues. I've been looking at the BORA .375" spacers and using extended lugnuts to get back lost thread due to the spacer. All the ET lugs I've seen are all .33" reach inside the wheel lug holes. For those that don't like spacers or think they're unsafe, I think it depends on what type of spacers you're using and making sure you get good quality hubcentric ones, and if you're using bolt on ones, regular mainenance, checking the spacer lugs. Not wanting or needing that much spread. Looking for the minimum that will let me run these rims and tires.  it does look to stick out a little, but I really want put these on. and use the stock all-terrains in the winter.
