I agree with you quiet cabin of Yukon is nice, but the fact that neither dealer nor GM are interested in fixing my issue and that three different mechanics agree unstable idle exists but they do not know why is very surprising for $60K car. I found a local GM expert performance shop. These guys are known for their integrity among Corvette enthusiasts. They will charge me $200-$400 to diagnose and if they find the problem I am not convinced that their finding would not fall into "within spec" trap. I am willing to spend this money and if GM/dealer still sends me to pack sand, I am the least litigious person in the world will go to Attorney General of the State. My wife is rightfully mad now as she drives it every day and hates the idle feel, truck also started to surge/jump when it comes to a stop or when goes from coasting on almost idle to acceleration.
Edited by dvzzz
An update on my case, a new service dealer has agreed to take on the challenge and using their recommendations of using premium fuel for a while - which is just about $2.00 per litre I might add! has reduced the issue but has not solved it. This dealer has begun the TSB for the engine mount but wit the strike the parts are delayed and may also get stuck at the boarder for a short period of time. I'm fine with that as at least I am moving forward.
How did you get the dealer to consider the mount replacement? In my case they are saying picoscope is 1.5G on mine which is less than GM's acceptable 2G. I am reading that picoscope measurement setup is so touchy that tech can make any measurement <2G. Truth remains that my Yukon irregularly hesitates in D and now even in P (in P a bit less noticeble). I have tried the Premium fuel but Hendrick GMC in Durham NC has told me not to put Premium in 5.3, period do not put premium in it, it burns differently, that is what Master Tech told me...
Sent from my iPad using Tapatalk Pro
Edited by dvzzz
Interesting theory emerged from one experienced GM mechanic who is also a GM big truck fanatic, he sees similar issue and repaired it by replacing ATF transmission issue, first run it with anti-shudder additive and then replace with fresh ATF and filter. I am not sure how exactly that might help with rough idle but he feels that it is most likely. Open to thoughts and ideas on this suggestion. My truck is only 8,000 miles at the moment.
  • 1 month later...
Well guys,
I took this TSB referenced in this note to the local dealer. Explained the issue and had the first part of the test run and proven with the PICO meter and after waiting a number or weeks for the parts, due to the strike and issues at the boarder, I finally had the work done yesterday and so far, I can positively say that I do not have any vibration or shudder (so far, fingers crossed). This is what a Denali should drive like - smooth as silk.
Obviously, a little early to be 100% certain but I feel we are pointing at if not over the finish line here.
Cheers,
21 minutes ago, ArrowsmithPML said:
Excellent to hear that.
I was asking my dealer to do engine mounts replacement on my Yukon but they said GM instructs not to do mount replacements any more as this is only a temp fix. Please keep us posted on how things are as you drive it more. If your fix is permanent, I will chase the dealer on my side to do it.
Well guys,
Cheers,
I find that a TSB that was just released in September more of a permanent fix vs something that someone might consider temporary. Frankly, I think that is a lazy answer and I would seek the advice of another place. I went to the other dealer and sat with the service manager in his office for about 90 minutes and we talked about everything, good, bad and indifferent. You won't get anywhere by being an ass so I always go in real nice and see where that leads.
Thanks
 Indeed. Great to hear that. I found a really friendly dealer, Service Manager is willing to help but telling me that GM does not allow them to do mounts because picosope gives vibration measurment at 1.5 which is <2. GM authorizes mount only if picoscope shows 2++. Do you happen to know what were your measurements on the picscope?
Here’s what mine said
488244483601ae56eb9103e7c6641bc1.plist
Way to go, Decline! Decline! that worthless wash!
Sent from Above
Mine was recorded as similar. #17-NA-166 and pico scope analysis done with spikes to 4.8, then 2.8 and then 1.8 at times - very erratic and unpredictable.
Anyone that has this vibration issue should really do everything they can to address is.
I was advised to run a few tanks of premium fuel - which I did and noticed a slight correction but it never went away. We had 3 of the 8 injectors replaced prior to that and I purchased a data logger and ran that for a while to generate a history. I also looked into selling it, trading it and just about everything in between.
Cheers,
thanks,  what parameter did you log and what data logger? Picoscope?
Cheers,
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
