Ok good that's what I thought I just wanted to be sure. They should arrive today and will be installed sometime this week or weekend. I will post pictures when it's done.
I am still undecided on what to do with the frame stop but I'm leaning towards leaving it for when I do push the system to its limits nothing breaks. If I am reading yalls comments correct leaving the frame as is would be playing it safe? Is that correct?
I would call Cognito about this. I'm not sure what you think is going to break, but I would be more concerned about leaving it and damaging the UCA on downtravel. I don't know if that is technically designed to be a travel limiter, as to my knowledge it's a service perch.
Yes I will post a detailed review of how they ride. They are the 2.5 all around with adjustable reservoirs.
I will give Cognito a call this afternoon.
Thanks again everyone for all the help!
Cognito will tell you to cut it and the fox or king coilover will be the limiting factor in travel.
Fox will tell you their shocks aren't designed to be the primary travel limiting factor and advise you to install limit straps.
When you mention this to cognito they will say they do not make a limit strap for a 1500 and "this is the first time we're hearing about this" and brush you off via email.
Ok then I will go ahead and cut it and hope for the best.
You should be fine if you don't plan on going airborne frequently.
but if you do go airborne frequently please post vids
Would leaving them be better for going airborn?
Sorry for all the questions
They won't help if you decide to do that^^ but they will extend the life of your shock/coilover if you repeatedly go airborne/full droop.
So I got a call from the shop saying they have never seen coil overs that you can't adjust with a spanner wrench or the wrench it comes with because there is so much pressure on them. They said they will need to put the shocks in a press and adjust them like that. They also said they install kings every week and have never seen this. Just my luck.
Any one else run into this problem?
What height are you adjusting them to? Mine were adjusted with the spike/wrench they came with and it bent the spike. So definitely some pressure there.
You might call King and talk to them about it - just to make sure that's what they recommend and it's not something amiss.
This is normal. Need to compress the spring to take tension off the ring.
Ok awesome that makes me feel better. So you cannot adjust these while they're on the truck?
In theory you can jack the truck up and use a autozone/auto parts store rental type spring compressor to take tension off. In practice it starts getting scary when you start cranking those little things.
And from my understanding/reading anecdotes, not all rental
compressors will fit all coils.
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
