Ok, my next question is, why is the Denali console less? Both without rear entertainment.
EDIT: I meant to circle the matching cocoa color; however it's still a higher price.
Edited by CoralReef
The top one is the frame of the console only. The bottom one includes the lid and stuff.
Sent from my Pixel 2 XL using Tapatalk
Does that include the wireless charging lid, with matching rear trim?
Trim plate-22816697
Rear Trim- 23449673
Trim plate-22816697
Rear Trim- 23449673
The bottom console will include everything but the side trims. The one you have circled on the bottom doesn't have the rear entertainment trim so it has a base level trim. If your truck is cocoa then I would assume you want console ending in 7260 which is a cocoa console with out rear DVD entertainment t option..
So this should be everything I need?
No that console isn't a complete console...your cocoa right?
Yes, I don't see a complete console under GMpartsnow.com. These are my options
I can add the rear trim pieces, but I would rather a complete console.
EDIT: The highlighted console doesn't show console lid or rear trim pieces. This is why I was wondering why it costs more, but shows no extra parts.
Edited by CoralReef
I guess 7260 should be a complete console. But i can't find the option where it shows the armrest and shit. For reference I looked up my console and it shows the same picture as that Cocoa
I am interested in purchasing the plug. I have the same truck in the video. 2016 Silverado LT
Pm @pgamboa and he will hook you up with a harness.  Just ordered mine from him, he shipped it out the next day.  Very responsive.
Yes PM. For some reason replies to my thread are not notifying me. Using the @forumname does send me a notification so thanks to @2017_whiteZ71 for that!
Hey phill, I’m interested in a custom harness for my 2015 GMC Sierra.. Let me know how this process works please... @pgamboa
Edited by Alexm
Added name
Hey guys/gals. Just wanted to provide an update to newfound information.
I had a member who purchased my 16-Pin center console harness. We learned that on some lower trim trucks, like the WT trim, is missing a power circuit in the 16-Pin cab side connector under the seat.
The symptom: the rear 12V Cigarette Lighter, the inside LED Light and the Wireless Charging Module were not getting any power.
There is a simple solution for this and that is to splice the missing power leg with other large gauge wire that feeds power to the front 12V lighter plugs.
So... for anyone that has purchased my 16-Pin console harness having this issue, please PM so we can address this.
Thanks again for all the business and support!
Phil
3 hours ago, pgamboa said:
I'm assuming this was my truck :)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
