9 hours ago, pgamboa said:
Yes PM. For some reason replies to my thread are not notifying me. Using the @forumname does send me a notification so thanks to @2017_whiteZ71 for that!
Phil...PM"d you 6 days ago, did you receive? Thanks, Rick
I'm assuming this was my truck [emoji4]
Could very well be... we’ll need to explore this if this is the case :). Text me for more troubleshooting.
Can you send me another PM to bring it to the top? I get 20-25 PMs daily, so it could have drowned.
My apologies. I usually respond within a day or two.
Has anyone purchased a 2014 full center console, black, white stiches, silver trim?  If so, do you have the part number listing and a source?  I want to upgrade my 2014 but I do not want the wireless charger version.
Thanks,
Rick
So... been reading all the posts and I think your harness can help me if I buy a 2018 Module. I have a 2017 sierra and previously tried to remove the little sticky piece from the original module. It would charge my Iphone 8 but it was sporadic so I gave up. Now I hear if you remove the little magnet as well it will work. Any insight into this? I guess my other option is to buy a new module and the wiring harness you created. If so, it is still available?
Hey Phil,
I rec’d the center console harness today. Got it all hooked up and was going thru and checking things to make sure it all worked.
I did a 2018 console, blk to brn cable and the blk to grey cable, grn to blk stayed in the glove box.
I did notice that the usb inside the console does not allow for car-play, but the front usb hub does, as well as the glove box usb.
Is there anything that can be done to fix the usb hub inside the console to have car-play? I have owned a 2016 1500 LT and a 2016 2500 LTZ (both with center consoles) and on both the usb inside the console allowed for car-play.
Thanks again for all you do here on the site! Much appreciated.
Big Rog
I'm wanting to swap full console for jump seat. Is there a harness for that?
Johnny01: Would you be interested in trading. I have a black with white stitching leather jump seat in my 2016 chevy Silverado. The truck only has 6000 miles on it. If they will interchangeable and yours is the right color. You can email me at [email protected]
Sent from my SM-G935V using Tapatalk
20 hours ago, b-garage said:
Hey Phil,
Big Rog
Phil messaged me back and said that some have reported this while others have not.
So, this is what I did:
I ran the blk/brown cable from blk HMI to brown usb inside the console. This feeds the usb hub inside the arm rest area. Checked and car play now works at the usb connection inside the arm rest area.
My next thought was to run the  green HMI to the input on the double usb connector of the front upper console part, and run the output to the usb in the glove box.  This meant I would need the grn/gray cable, but I had purchased the blk/gray cable. And also would need a black to regular USB connector. Not sure if they even make this or not.
But I had some wire cutters!
i cut he blk/gray cable in half, and did the same to the grn to USB from the glove box. Swapped ends so that I ended up with the glove box USB with a black connector on the other end instead of a green. I then plugged the blk end into the output of the double USB hub in the front upper console and the other end into the glove box. I went ahead and ordered a new grn/gray cable, but just to test things out I spliced the left over ends to make a grn/gray cable. Plugged it in from the grn HMI to the input of the double USB hub in the upper front console  and now have car play at all three USB locations!
Go figure.
On 2/15/2018 at 4:57 PM, DSlade said:
pgamboa
i have a 2015 Silverado. how can i purchase your harness?
Hey Phil,
i have my 2017 Silverado and I have an OEM console on order now. I have the bracket and side trim on order as well. The only thing I need is this harness correct? Please let me know what else I need fin anythjng and I would like to order the harness throug you.
Go figure.
Thanks for providing this detail.  It difficult to fully understand the signaling flow and can only take things based on my personal tests :).  There are many that were successful in using the cables that I suggest while others are not.  Makes me think the output of the double USB is bad?  Anyhow, thanks for sharing this!
Check out my thread here so you have an understanding of all the requirements for this upgrade.  Then PM to order.  Thanks!
http://www.gm-trucks.com/forums/topic/207916-2014-k2xx-center-console-retrofit-plug-and-play-harness/
27 minutes ago, Matt McQuown said:
Hey Phil,
Harness and 2 USB cables based on your center console configuration.  Please see thread here.
Interested in a plug and play harness for my 2017 silverado. I have the center console, side trim, and front bracket on order. Please let me know what I need to do to order the harness from you.
Thanks.
OMG!  I'm going to get my console Thursday!!!!  I'm so excited.  lol   Taking out the jump seat to get with Phil.
Damn!  I don't have the size of bit to unscrew the seat!  To the hardware store!!!
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
