Tapping sound from passenger side
Hi all,
I have a new 2018 Chevrolet Silverado LS Z71 Crew Cab with less than 500 miles. All is great except for a tapping sound that seems to come from the passenger side of the truck.
  1. It sounds exactly like something is lightly tapping on the windshield, but nothing is there.
  2. The sound appears to be higher up in the cab, not like it's coming from behind the dash (but that could be an illusion).
  3. There's not a rhythm or pattern to the sound. It just taps sporadically while the car is moving.
  4. It doesn't happen while the car is sitting still, only while in motion.
  5. Speed or acceleration doesn't have any influence on the sound or rhythm.
  6. I thought it could be something in the speaker, but I turned the radio off, and it still happens.
  7. I disconnected all phones and Bluetooth devices.
  8. I turned off all the AC controls and fans to see if that was it, but no luck.
  9. I looked all through the cab for anything that appeared to be loose.
  10. I did hold my keychain to see if it was possible that was tapping.
I'll take it to the dealership next week if I can't find anything and report my findings, I'm just wondering if anyone else is experiencing this unique tapping sound.
Thanks for any help.
Shawn
With this unique issue and yours being a brand new truck, hopefully the dealer can solve your noise problem.
Good luck!
I hope the dealer can find something, I just got a 2018 Silverado CC myself. It kind of sounds like it could be one of the connectors/ cables inside the door that didn't get held down properly bouncing around and tapping against the door panel. I could be way off though... I hope you figure it out!
Don't know about the newer trucks, but the GMT900s had an issue with the trim around the windshield making a tapping noise, especially if the truck had a hood deflector installed
I know it sounds silly.. but check the seat belt.  If the seat is all the way back, the seat belt will hang up sideways and the plastic around the seat belt will tap against the plastic on the pillar.  Happens to me all the time someone gets out of the passenger side.
Good Point. I notice this as well.
On 7/26/2018 at 9:51 AM, shawnrouth said:
Hi all,
Shawn
I have a 18 cc with 600 miles on it and  I have the same thing Going on the exact scenario is you were saying  but Because I work on cars I can pick up noises pretty well from where they’re coming from and I found out that it was the center bezel Around the radio was not cliped in all the way  mine would do it when accelerating in between a  gearshift when the vehicle flexed a little it would tap or pop
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
