Chevy Trucks & SUVs Are The Longest Kept Vehicles In These 6 States - Is Yours One of Them?
John Goreham
Staff Writer
8-29-18
Recently, our colleagues at iSeeCars.com released a report that detailed which models were the longest kept by owners. This is a metric that can help to paint a picture of how long vehicles last, or are still interesting and satisfying to owners. Following the report, GM-Trucks.com reached out to see if the data generated had any more details. It turned out that the data also reveals which vehicle is the one that owners keep the longest in each given state. Chevrolet vehicles are the ones kept longest in six states. They are: Arizona, Iowa, Kansas, Maine, Missouri, and West Virginia. The chart above shows the state by state breakout looks with the vehicle that is kept the longest in each state. Coincidentally, Ford also has the longest-kept vehicle in six U.S. states. Honda and Toyota dominate the rest of the country.
By any chance, do we have any members who own that specific vehicle in that specific state?
*Note: Data was not available for every state. Hence the total that is less than 50.
Currently have a '14.  Prior to that I put 245K on my '05.  Have had a "Silverado" since 1997, ('97, '00, '03, '05, '14)  Drove a '72 Chevy Van in High School and long time after ('75-'81).  I wonder what would happen by state if they did a "loyalty" survey on Brands, Models, etc..
Funny Mississippi is never in nothing important we have 5 GM products here. 1996-2003 -2007 and 2 2015s.most were bought new.
By my count only 39 states listed, a couple of glaring omissions where vehicles see severe duty are Alaska and Montana, there may be more,  but I doubt Honda comes out on top in states such as those. The Dakotas are missing from the list too.
I see nothing in this metric for GM to take any pride in.
I love my old Chevy which is my fifth. They fix pretty easy as a rule and hold up well if you can prevent  corrosion. Here in Vt with it’s ridiculous inspection protocol, a lot of Chevys will be junked in coming years.
But the biggest knock I perceive is that Toyota’s Honda’s Subaru’s require so little to keep them going. But for serious work trucks, there are only 3 choices, and to me Chevy is still the least problematic. If Toyota were allowed to make something more than a half ton, a lot more of the work truck market would head their way, initial cost notwithstanding.
And how come not a single HD truck shows up on this list. After all it’s not about sales volume but length of ownership.
My personal best was a 22re Toy p/u that I bought as a two year old rebuild and drove 15 years, and it went at least 3 more after I sold it. Oil undercoating, folks. My only new truck was a Ford that was dead in 125k and steered like a pig, esp at night. Toyota’s and Chevys just track straight for me.
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
    • 87 down as low as $5.14 here... winning!
