Nice Sierra! Go to Tailgatefix.com starting Friday. They have a fix to prevent denting the new 6 way tailgate if you have I hitch in the reciever.
Installed my winter tires and wheels on Sunday (Toyo Observe G3-Ice tires); going to fabricate some sort of setup to hold the sandbags over the rear axle Friday (I move sandbags in and out of the bed before and after large storms).
Installed a QC 3.0 Port in the back to charge more devices for the kids.
Going to have to add another one as I have 3 kids and 17 million devices that all need to be charged back there.
Sent from my SM-N960U1 using Tapatalk
My dad use to get old tractor tubes, cut them in half and fill them up with sand and then used hose clamps to clamp the ends shut.  This worked great for extra weight and the rubber tubes didn't collect any moisture and if you needed the sand you could just undo one of the clamps.  Plus they were easy to handle and as well as not move around much in the bed since the rubber helped keep them from sliding around.
That's a great idea!
About a week or so old but here to share nonetheless. Limo on sides and back with 35% on the entire windshield with a limo strip at the top. Rest of build should start soon, if I can stop second guessing myself that is.
Looks nice. I really like the rims with that color. I am really considering those when the time comes. But like you I can’t make my mind up on if I want to go aggressive or stick to more factory with just a level.
Dealership installed the Kicker Audio System  but cut corners and decided not to install the lights. (Many dealers do this apparently) I didn't really care for the system but if they put it in there and I have it... I wanted the lights. So I bought the multi-pro tailgate lights kit and popped the lights out of the frames and put them in the kicker system.
  • Like 6
I’m right there with you. I have looked at every single truck I could find online with a similar setup. I have seen several trucks with a small lift and these same accessory wheels and truth be told it’s not the vision I was hoping for. Now with that said I’ve seen some with the other 22 accessory wheels and it looks great. I’ve also wrestled with lift or leveled decision due to warranty. The dealership I bought from says it’s a nonissue but they are not in my local area. The few I have visited here said it will absolutely be denied warranty work regardless of its suspension related or not. I finally got a service manager to admit that it basically is up to a manager to notify Chevy that anything has been altered and of they don’t say it has then warranty is no issue at all. I guess it’s everyone’s personal decision to risk it or not.
funny side story I wasn’t supposed to have these wheels. I was supposed to have the rst 20’s but when I went to get the truck they had swapped them out with a lower package rim. I pointed this out and the gm said find some on the lot or we can order yours. A factory ordered truck had these in the very back, still had plastic inside and out. I half jokingly said I’ll take the black ones in the back. Without even going to look he said done and we will throw in a spray in liner for no charge since you had to choose different wheels. My sales guy was not happy when he couldn’t talk the gm out of it once he realized what he had done.
You lucked out on that hahaha. It’s tough for me as well because my father in law is the service manager for a Chevy dealership and that’s where we take our vehicles. He does everything the right way. Might just wait until the warranty runs out then start working on it. My truck doesn’t get much use (only 400 miles in two months). Good luck on your build and can’t wait to see some pictures!
    • Paid $2.72 for E85 today.
    • Welcome back! No, it definitely doesn't pass the sniff test. Even "ceasefire" needs an alternative definition these days.    $5.29 at Kroger today
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • 2024 Silverado 2500 HD LTZ grille no camera Parts list   84603331 84913656 84913657 84913654 84913655 84911567 84911568 85646092 85646093 85797921 85797922   11570637  x10-15   grille/bumper bolts 11546500  x10      grille clips 11571006  x10      push/retainer clips 11546454  x6       nut retainers 11611609  x6       M5 bolts 11610700  x6       molding/trim retainers
    • And use RA's 5% discount code if you buy from them.  google for the code, one is always available.
