Just got my first full sized.......2020 Seirra Elevation, lowered 2" front and back, a bit more to go once the new 4" rear kits come out; running 24x10" Niche wheels with 305/35/24 Nitto 420V wheels.
Elevation didn't come in leather, but I got the dealer to throw in custom leather as part of the deal, leather goes in on Thursday....leather plus heated seats in the back for my spoiled kids ?
Gorgeous lookin rig !   Thought that was a roll bar behind the rear window, but just realized it's your tonneau cover.  Truck looks great...
Traded the 2017 Silverado for a 2020 Sierra last Friday. Bed liner, bed cover, and window tint done Monday!
On 3/17/2020 at 5:29 PM, gt tangerine said:
22s back on!
My favorite stock wheels.  Looks great.
What lowering components did you use? I'm assuming spindles in the front? I dig the wheels also. I had considered those last yr when I was in the market but they weren't in production yet. The rake is not that bad with the 2/2 drop. The back looks like it lowered more than 2".
Very sharp, looks like a silver tuxedo!
On 3/10/2020 at 6:47 PM, gt tangerine said:
Red tow hooks look good, work with black and chrome, thinking I might paint mine this weekend since I can’t anywhere... it’s gonna be red plasti dip red :)
On 3/10/2020 at 2:46 AM, NICK19LTZ said:
2019 LTZ 6.2 with 2”GM lift and RC level Looking for anyone with a 2020 LTZ 1500  with tow mirrors and want regular ones and want to swap please message me willing to pay shipping located in Arizona thanks
do you have the technology package ?
Congratulations on your new truck.
One of the best looking T1's on the site IMO!!! Well done!
2 hours ago, NICK19LTZ said:
I don’t
There are a couple threads on this topic, but believe it’s thought that you could swap between trucks but both would have to be equipped the same way.   Wiring etc.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
