On my trail boss LT it's part of a package. The moon roof was an extra option. I would have preferred to have neither.
Sent from my SM-A505U using Tapatalk
On 10/5/2020 at 10:33 AM, Spyderwebb said:
Interesting story;  I took my truck in for its first service this morning and while visiting with the Service Adviser I asked what their process was for repairing the leaking back windows on the Silverados, not that I wanted them to do it this morning but because I wanted to know how they were handling the issue.  To my surprise I was advised that they were not familiar with that problem!  This is the top selling Chevy dealer in Kansas and I would estimate they sell hundreds if not thousands of Silverados every year!!
I expressed my surprise and shared that on the largest GMC/Chevy - Silverado/Sierra forum there are hundreds of pages pages about this issue....so there must be a plethora of active claims on it across the country, right??
Anyway, for now I am not going to have them experiment on me with a band-aid fix, I'll wait as long as I can... or until Chevy recognizes the issue and comes up with a responsible and effective correction to this problem!
Needless to say I'm concerned!
Don’t feel bad. The largest dealer in Texas and routinely largest in the US is my local dealer. Both times I’ve taken mine in for the leaker, they acted like I was speaking German to them. When I pressed my advisor, he said he had never heard of anyone having the issue. That’s when I stopped caring about the leak, and just monitor it myself and use a towel to keep the rear dry.
The dealer in San Diego that just installed my GM Accessories Baja Designs offroad light is very aware of the rear window leak, and they aren't that big of a dealer. I've been here for over 3 weeks now, and it hasn't rained yet. I know Texas has had rain since I left it a little over a month ago. Imo, it sounds like your dealer may be full of [emoji90]
I will tell you all these dealers are the same. I've had mine repaired three times at the same place and each time they act like they have no idea about this issue.
20 LT Trailboss 2400 miles with rear window leak on driver side. Water is weeping from the top track of the slider. Dealer has had the truck for a week and told me they’re pulling the rear window to reseal it and check for cracks. Said if it’s cracked they’ll have to replace the window. After reading all these posts I’m very doubtful this is going to be fixed
Joining the club of a leaking rear window.  From what I’ve read this issue is hard to resolve.  Anyone ever try and site Lemon Law to their dealer? My truck only has 8k miles. Hate the thought of this window allowing water inside for the life of the truck
On 10/5/2020 at 1:56 PM, UGADawgs said:
All these sliders will leak at some point. Prove me wrong. ?
Add a 2020 AT4 with a build date of 8/20 to the list. Just got the truck back yesterday from having the valve springs replaced, now the rear window is leaking. I thought buying the 2020 I wouldn’t have these issues, haven’t even made a payment yet. Back to the dealership tomorrow!
  • Sad 2
Man, I just took delivery on my new AT4 yesterday with a build date of 09/11/20.  I may have the newest built truck on this forum!  Fingers crossed I don't have this issue.  I did have it with my '19 TB LT.  It was an early build 08/18.
My 2020 Trail boss is leaking at the same spot as your truck. Truck has 2400 miles on it. Dropped the truck off last week at the dealer I ordered and purchased from. Told me they we’re gonna have to pull the rear window and reseal it. Called me yesterday to tell me it was done. Went to pick it up today and found what looked like they just applied the sealant from the outside to just the corner of the leak with out pulling the window or the rear brake light. Needless to say the truck is still sitting at the dealer
I had mine in last week. They told me they had to order a window and would call once it arrives. It has been raining here all day. I'm sure my truck is a fishbowl right now. I'm not impressed.
Does anyone actually know what causes the frame around the window to crack? Pressure/stress? Heat from the defrost? Maybe water freezing in the northern states?
Not officially, but I believe 100% it’s flex in the structure. Nothing else makes sense. That’s why further revisions of the window haven’t solved it, it’s not a window problem. They took too much meat out of the structure to save weight.
If that’s the case, it’ll be interesting to see what(if any) changes are done to the 2021s to prevent this.
I am not confident they’ve done anything for 2021. Trucks are already on the lots. And we have here a late 2020 in this thread (built in August) that leaks. What’s another month or two gonna do to solve it when they’ve known about the problem since late 2018...
Really hoping it’s ironed out for 2022. If I buy trucks 3 years apart with the same problem, I won’t be happy.
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
