On 11/14/2018 at 7:31 AM, Demon said:
Just a heads up to all the other 2019 owners out there.  Last night I noticed water on the top on the back seat on the passenger side and my rear window is leaking.  It looks to be coming from the area around the sliding window rail.  I spoke with the dealership last night and will be dropping it off today for them to fix.  I'm not really pissed off about it because this is the kind of stuff that happens when you buy the first model year of a new design but I just wanted to give you guys a heads up on something to look out for.
Just happened to mine. Have to take it in 😭
Somebody fill me in on where we are with this. Do these windows still leak into the late 2021/ 2022 models??? Had a 2020 built in July 2020. It had a slight leak. I added TrimLok weather seal tubing to the spoiler gap and never had an issue after that. Truck got totaled. 2022 is being delivered next week. Wondering if I need to do the same on this truck.
I done the same Trimlock tubing on my 2020 and I've been in some hellish storms going thru Texas and not one drop found it's way in.
Following @Kclyatt’s lead. Just put two tubes of windshield sealant into the top of the window between the spoiler and the window. Contemplating getting another.
Next will be to seal up the gap between the spoiler and the cab using the weatherstrip he recommended from Lowes:
https://www.lowes.com/pd/M-D-10-ft-x-19-32-in-Black-Auto-and-Marine-Seal-Rubber-Marine-Automotive-Weatherstrip/1038917
After that will be a sealing of the brake light. Still researching that part.
Edited by AJMBLAZER
What’s a wondow?
23 minutes ago, Thomas Sampson said:
Leaking back window in 2021 Chevy Silverado. Dealer says it’s not covered and 250 to fix!!!!
Sounds like you need to go to a different dealer
That would only be true if you have more than 36K miles!
And if you are out of warranty, then I would look for someone to do the repair that’s detailed in the sticky thread in this forum.  If you can’t DIY, then paying someone to do the repair that will work would be better money spent.
Hi everyone,
I’m having the same issue as everyone else. I already replace my sliding window with a solid one and I’m still having the same  water leak. Any one has an idea what else could it be? I’m passed my 36000 and bumper to bumper does not cover it.
Edited by Stallion_08
I have a 2019 Chevy also. It has been at dealership 4 times because of my back glass leaking. Replaced glass twice. Then other three times just tried to seal they said. Well it’s back again now what is the correct way to handle this situation.
2 hours ago, Stallion_08 said:
Hi everyone,
Wel….I hate hearing this. I’m bringing mine in Monday to put in the solid glass.
Alright gentlemen, I found the leak. It wasn’t the solid rear window. The dealership did not fastened the nut completely and the weather strip was damaged. the water was going through the hole that has the yellow guide on the spoiler. The round gasket was ripped so I bought a new from advance.
It did stop the leak but let’s see for how long. I ordered the weather strip from lowes  and I’ll replace the damage one as soon I arrives.
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,294 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
