What and Where do you always carry in your truck.
Just wonder what others Keep in their truck.  I'm pretty minimalist so mines a pretty short list.
Driver door pocket- Gloves, toque, handfull of napkins, Microfiber cloth.
Center console - insurance and registration, flashlight,cheapo tire pressure gauge, knife, usb cable and a thumbdrive full of music(in the usb ports)
Ash tray - Remote for interior leds
Under pasenger seat - pack of 8 ratchet straps i picked up.
Under Rear seat - snow brush
Plan on picking up a 4in1 hitch and a tow strap after christmas.  (taking recommendations on tow strap)
  • Replies 33
Center Console:
- Pen
- BlueDriver Scan tool (Bluetooth units; reads BCM and other computers in the vehicle, so far more useful than most scanners)
- Small back scratcher
- Flashlight
- Key to my boat's gas cap
Glove Box:
- Registration and Insurance cards
Bed (have the UnderCover soft wheel well saddle tool pouch):
- Ratchet straps
- Lithium Ion jump pack
- Tow strap
Inside:
Glove compartments empty
Center console, insurance card, usb charger for my iphone
Rear seats: baby’s car seat
Backpack with my fishing tackle
And 1 gauge jumper cables under seats and umbrella for my wife incase it rains
Bed:
1 fishing pole with a baitcaster on it
Tow strap
Extra 3 way ball hitch
Front center console: USB to SATA hard drive bay with a 512gb solid state drive installed in it, my windshield mount for my cell phone, fast charge cigarette adapter for my cell phone, change holder (never gets used but it's there if my ezpass breaks and I need a little change), notepad, pen, and a log I use to track my mileage and how much fuel I put in every time I fill up along with what grade of fuel I used.
Front center seat: OBD2 bluetooth adapter, small/outdated map of WNY but good in a pinch if I had no cell phone or whatever, small pigtail adapter to use in the rare event the security bypass module for my remote start fails and I can't start the truck (all I would need to do is just connect that jumper and it will put the security wire back to factory and I can start the truck from the key again), LED flashlight, nail file and nail cutter.
Front dashboard/glovebox: a pair of gloves (who would have thought, gloves in a glovebox), owners manual, proof of insurance, registration, small bottle of ibuprofen,  a few imodium pills that never get touched, small bundle of tissues and napkins, cigarette lighter that is unused, the little pouch you can stick your ezpass in if you don't want it to get read when going through a toll.
Underneath rear seats: a few small towels, fire extinguisher, tire pressure checking tool (one of the long ones you can use on semi's), small blanket, bungee cords, 5 or 6 long ratchet straps, spare pair of headlight bulbs, ungodly long tow strap, 2 gauge copper jumper cables.
Truck bed: nothing but the somewhat leaky ranch truck cap.
Drivers door cd's(never use but dont know what to do with them) and a refillable spray bottle car freshener
Glove box insurance and registration,wheel lock,map
Console cables tablet headrest mount, tactical knife and gun, pen, owner's manual in case, HPT, dental picks and change
Front console led controler and more cable hard wired to truck.
Back under seat sub box with stainless hitch behind it
MOST IMPORTANT all back seat has dog cover cover everything but doors and can still get kids seats in. Has cargo pockets with dog leashes and poop bag.
Oh bed has BakFlip F1 and under it moving blanket ,cardboard, tie down strap, double loops, bike cable lock, and sometimes a 2×4.
drivers door compartment: mag lite
under back seat: small tool box with simple hand tools, ball hitch, snow brush.
undercover swing case in bed: tow strap, ratchet straps, gloves, jumper cables, other hitch, etc.
1 hour ago, 14cris said:
Inside:
Bed:
Tow strap
got to have a rod and reel!.. never know when you'll need to wet a line!
drivers door... howler brother's koozie... a bunch of crap in the center console, and the rest is in the tool box, from tow chains, straps, jack, tie downs, tools..etc...
Tow strap
https://www.theisens.com/products/economy-tow-strap/17171537/
I run two of these (well the HD version on these anyway can’t find that link) in my 3/4 ton gives me 60’ of length if I’m or somebody I’m pulling out is farther off the road than that call the tow man cause it ain’t happening anyway. Carry 2 6.5 ton 7/8” screw type D rings and 2 tractor hitch pins with the rubber coated loop handle and cotter pin with retention wire (rubber loop works good with gloves on and wire so don’t drop and loose pin in snow) forget what size I found to fit the hitch hole but it’s a tight squeeze. Strap ends are loops and will slide into any 2” or 2.5” hitch then hitch pin in hole, if a receiver in the hole or smaller hitch can loop strap around the hitch assembly, can loop/hook most tow hooks/loops (also carry a short “axle” strap will work with smaller loops) or go around a differential or A arm assembly if needed. Use both Drings if using both straps one as a just in case/share the load. Also can loop hitch to hitch with a Dring if pulling in a tight spot to make a 15’ strap. Straps are obviously oversized could pull a semi with these but I’ve used this set up for 8 years now and have yet to break/fray one and don’t worry about dragging them over rocks, up ditches, around poles, ect. Also they are heavy enough that I can roll them up and leave them in the corner of the bed behind the cab and won’t blow out. If I break, lose, bend something a replacement piece is as close as the nearest “farm” store and whole set up is still less than a Buba strap...
found a link for the “HD” one
https://www.amazon.com/Erickson-59800-Recovery-Breaking-Strength/dp/B003AP86S0/ref=sr_1_4?ie=UTF8&qid=1544797383&sr=8-4&keywords=Erickson+tow+strap
Thanks for the reminder.  Next week we're heading off to visit family and do some holiday tourist activities.  When travelling, I carry a good quality first-aid kit, snack-bars and blankets.  These items are in addition to the usual tools straps and entertainment already mentioned.
Center storage - GPS, flashlight, pen, small note pad, tire gauge, snack bars, candy bars.
Center council - 2 bottles water.
Center small storage with the door - keys for cabin, key for front door.
Drivers door - quart of oil, mail box key, leather gloves.
Dash - in winter a pair of knit gloves for cold steering wheel.
Beside drivers seat - winter gloves.
Passenger door - hand wipes, bottle water.
Glove box - users manual, maintenance records, tissue, head phones, Range device.
Back seat - hitch ball, coat, hat, snow brush, window shade, blanket.
Bed - tool box, spare tire for boat, bungee cords and tie down straps in a container, anti freeze.
This is a lot of stuff but my travels can be rural with no cell phone service.
We go for rides to get out of the house to see wild life.
If you have a problem you wait until someone comes by.
I said before in 50 years I have broken down twice due to part failures so I do what I can.
I'll do my best to go by memory on this one.
Driver's Door:
Change
Doggie bags
Leatherman tool
Tape Measure
Front Passenger Door:
Rear Driver Door:
Leather Gloves
Two full water bottles
Rear Passenger Door:
Lithium Booster Pack
Rags
Centre Console:
Large Towel
Glove Boxes
Hand Cream
Mini bike pump
Spare bicycle tire tubes
Wheel Nut Socket
Owners Manual
Insurance / Registration
Extra phone charge cable
Tire Pressure Gauge
OBDII Reader
Pen
Paper Towel
Dash Cubby
Snacks (cliff bars)
Chap Stick
Tylenol
Under Driver Seat
Air compressor (sometimes)
Driver's Seatback Pocket
Backroads Map Book
Under Front Passenger Seat
Chain and Padlock
Under Rear Seat
Breaker Bar
Ratchet / tie down straps
Snow Brush
Umbrella
Tool Bag on floor, behind Driver Seat
Tow Strap
Shackles
Liquid Wrench lube
Stubby Wrench Set
Screw driver with changeable bits
Small Vice Grips
Basic first aid kit
Bed
Empty, ready to haul.  I hate having things I have to move if I need the full bed.
Sunglass Holder : Sunglasses
Center Console : Wet Wipes, Spare Change, Winter driving gloves, Spare Change and phone Charging Cord.
Under Rear Seat : Tie Downs, Detailer Spray and Microfiber Towel
Glove Box: Owners manual
Center Console:
- Pen
- tape measure
- Role O'Toilet paper
- Flashlight
- GPS unit
- 9MM
-screw drivers
- Tire Gauge
- CD's
Under Hood
- Ratchet straps
- jumper cables
Bed
- Crow bar
- Wood
- Chain
Glove Box:
- Trailer adapters
- Brake controller when not in use
Four way under the seat, phone charger, pens, hairbrush, flashlight, ibuprofen, tums in the console and a 9mm on me.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
