7 hours ago, kmeleon said:
John, do you know how to get a hold of a set of harnesses for the front dash speakers? I'd rather not cut them. I have 2 sets coming for the front and rear doors.
I’m interested in this as well.
Also, reached out to this eBay seller regarding these pillars, awaiting a response.
https://www.ebay.com/itm/Custom-Fiberglass-Pillars-2014-2021-Chevy-silverado-Request-For-All-Vehicles/313381928800?hash=item48f704bf60:g:-d0AAOSwcUZgAQCw
They also have expanded PVC speaker adapters, I asked for pics of the finished adapters.
https://www.ebay.com/itm/Speaker-Adapter-Plates-2019-2020-Chevy-GMC-Silverado-Sierra-6-5-Expanded-PVC/313376771005?hash=item48f6b60bbd:g:0qcAAOSwbRhf-4lu
I wouldn't be surprised if the harness that works in the door would work in the dash as well. GM tends to keep those the same,at least they have on a lot of their models. Order a set of those from Crutchfield and if they don't work then just return them OR try to doctor them to make em work.....like maybe removing the pins from the connector itself and inserting them into the stock pins.Who knows,they might fit??
Another thing you could use are posi taps. They are much less invasive than typical splicing.In any case if you go a route that you have to manipulate it then email me and I'll give you the wiring colors on each side so you're not guessing.
Edited by JH1973
Ok, I'll let you know if I need some help. I have two sets of connectors on order so I'll see what the difference is at some point.
Another question for the masses, obviously you can't really use a DMM to set the gains on the amp because we have no idea what the factory RMS rating is on the Bose amp. So my plan is to use an o-scope to verify at what volume level the signal starts to clip. Unless someone already knows this?
I pulled my Bose dash speakers this weekend to confirm what ohms they are. Here is some pics of the connectors as well.
Edited by sclemmer
Can only upload 4MB.
I don't see any pics of the connectors....
Did they unplug as one or did each wire unplug separately?
Edited by kmeleon
I guess that pic put me over the limit. It was one connector.
Excellent, have you had the door speakers out yet? Any chance they're the same? I'm still waiting on my harnesses to show up so I have nothing to compare these to.
Which harnesses are you waiting on?
I'm waiting on door harnesses. I'm wondering if the dash speaker connector is the same as the door connectors? I'd rather not cut any wiring when I install my system.
I should have been more clear, which brand harness?
The dash speaker plug is different from the door speaker plugs so they won’t work. Don’t cut off your dash speaker plugs. Just tap into each wire and extend it to your replacement speakers. I did this a few days ago.
Use wire strippers to score the wire insulation behind the factory plug and pulled the insulation to each side to expose the copper wiring. Be careful not to damage any copper strands. Wrap your new wiring around the exposed copper and solder it. Seal it up and you’re done. The factory plugs will still be there in case you ever need them again.
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
