1 hour ago, Silverado4x4 said:
TrailDemon have you check the level after they replace the oil line? You look like your 1/2 quart low on the stick now with that said if they replaced the line at the dealership then fill the motor with oil to the proper level on the stick and then started the motor the empty line and oil cooler will purge with oil (getting the air out) giving you about 1/2 quart down on the stick so fill it up to the proper level on the stick and keep an eye on it.
I did go over the oil leve days after and to me it looks like it’s missing more thn 1/2 quart ?
On 6/15/2019 at 10:41 AM, jasnak said:
Not an oil leak, engine burning oil now because of the oil line failure and blew all the oil out. Read the thread.
I think the last few years have shown these di gm engines consume oil, some more then others. Just look at the couple post were forum members took the head off their engines and found oil/carbon deposits all over the valves and top end of the engine. A reason why many here have chosen to install catch-canisters to help reduce the oil build up.
first service at dealer 6500 miles no signs of any oil leakage anywhere including cooler lines and crimps, at least that's what I was told!
Changed my oil again 5,000 miles did the first change at 900.4,100 miles exactly at full mark before change. PP 4qrt 5/20 4 qrts5/30  Napa gold filter
Edited by K455
On 4/30/2019 at 1:31 PM, quicksilverc5 said:
In looking at the cooler design, it looks like you may be able to replace the whole setup with an AN fitting/braided line setup.  The attachment to the block looks to be similar to the LS designs, When I have a chance I need to look at the attachment to the radiator.  Of course if you do this and mess up its all on you.  Other option is to do a delete.  We'll have to see if its an issue like the window....bad supplier or if it a design flaw do to pressure changes.  I notice that my Oil Pressure varies quite a bit while driving and that could be stressing the connection.
Can you post a pick, if you havent already. going through all the pages
Hey, got my oil sample back from a 3rd party after this oil cooling line blew all the oil out of the engine  and it came back good no traces of any metal.?  Good peice of mind to have after this incident. If this happened to you I’d recommend getting your oil tested too. Cheap to do for
reasurance
  • Thanks 1
  • 3 weeks later...
  • 3 months later...
2019 Silverado, 23.5k miles.  Oil Cooler Line fail.
Replaced line, refusing to provide CCL letter from the GM Customer Service folks...  Wondering who might I escalate this with?
I am just curious what you filmed this with
  • 1 month later...
22 hours ago, jasnak said:
Just wondering if GM fixed this problem or is anyone still having this problem with the cooler lines.
Funny you brought this back up because I was thinking about this the other day and it seems that they all posted the problem all around the same time and now we hear nothing.
I was down the dealership on 12-06-19 for the recalls on my truck and was talking to a friend of mine who is in charge of the mechanics in there shop and he said since they have been selling the 2019 T1 truck he has yet to have one come in the shop for a oil line failure, not one.
Edited by Silverado4x4
Haven’t seen anything for months on the FB group either. I don’t think this problem is as widespread as 17 pages would suggest, and probably no more common than it was on the last generation.
Now the window leak....that’s something!!!
2019 GMC Sierra at4 6.2 liter, 11,000 miles. Driving at 20 mph all of a sudden alarms going off saying turn off engine zero oil pressure.I immediately turned it off. Got out to look at it and notice all the oil pouring out the front bottom of grill. Called tow truck and back to dealer. Let’s see what happens.
Edited by Jaels
Typo
  • Sad 2
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
