15 minutes ago, hotrodz37 said:
Where’d you get the fender badge that excludes the engine size? Is it from an elevation? If you have a part number that would be awesome. Truck looks good, don’t see many lowered ones these days.
I got bored. Heres the part numbers
84431305
84431304
84431305
84431304
You are the man! I’m usually pretty good at searching but for the life of me couldn’t find these for some reason. Thanks again!
What are they guys running aftermarket wheels using for TPM sensors? I want to keep the factory ones in my stock wheels for winter. Are any of the aftermarket sensors working with the 19/20 trucks?
Has anyone recalibrated their speedometers after changing wheel/tire diameter?
I have a 2019 Sierra Elevation.  It was a manager’s demo.  Came with levelling kit and 275/65R20 BFG KO2’s on factory Elevation black 20” Snowflake style wheels.  Tires now have a 65 aspect ratio now vs factory 60.  Obviously with the level and slight diameter change there’s no rubbing or anything.
Also thinking about getting a set of dedicated winter wheels and tires.  Probably go 17” or 18” to save some cash but wondering if that’d screw up my speedo and other components on my truck?
Edited by madconcept
On 12/19/2019 at 6:15 PM, Cmillerjr said:
Stock wheels with 295/70 R18 Cooper Discover AT3/XLT.
How do you like the Coopers? I'm debating between them and the Nitto Ridge Grapplers.
I love them. Minimal to no road noise, great in wet/snow/mud, even wear and great mileage. I rotate every 5-6k miles. For a load range E tire they aren’t as heavy as others either. I’ve ran Coopers on my last three trucks. The last set had over 25k on them and 12/32, before I traded the truck in.  I think I could have easily got another 20-25k out of them.
I don't do any off road driving other than my 1/4 mile long gravel road. Would you recommend either or both of the tires for that kind of driving? We get snow a few weeks a year at our elevation, sometimes 2 feet worth.
Absolutely, the only time I’m off road is during hunting season. I’m on the highway 75% of the time. I’m in Pittsburgh so we don’t see 2 feet of snow, but never had an issue in 6 inches or so.
On a side note, what kind of MPG u seeing around pgh? I have stock 5.3/10spd (minus a cap) AT4 and I am seeing 14.5 city/MAYBE 16.7 highway
Around town I’m getting 14 and 18 on the highway, that’s with the larger, heavier tires and leveling kit. I was seeing 16/20 stock.
I took a three hour trip to Harrisburg and peaked at 28.2.
I'm still on my first tank, and looks like I'll get 525 miles on it.  Truck's computer shows best of 28mpg.  I'll calculate it once I get a fill up.
On 7/15/2019 at 10:27 AM, bamulk said:
Method NV 305 18x9 -12 Offset
Cooper Discoverer S/T Maxx 295/70/18
1.5 Level (Trailboss)
Slight Rub on mudflap on full lock.
Can you post more pictures of the front. Id like to see the front stance. Trying to get a similar setup but ive seen other trucks that dont look this good with the same rims.
On 12/1/2019 at 8:26 PM, jonkae said:
Are those the satin or glossy finish? I was on the fence between fuels or these and your specs just made up my mind.
Glossy black ? Please give me aside shot if you would.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
