2 hours ago, PureZ71 said:
Not exactly sure because I had removed my mud flaps and the bracket behind them  before due to my previous setup (Stock wheels + 2" spacers). They will for sure clear the calipers. But -12 is just the perfect amount IMO.
Thanks!!
On 7/16/2021 at 8:28 AM, Chad Nelson said:
Ahhh I see the fragility of the snowflakes have made there way to this site too.
Ok boomer, I can assure you I am no snowflake. Just letting you know I think that your comment was being an ass for no reason hating on someone's pride and joy. But yes you can voice your opinion as you see fit just as I can. Take care.
On 7/17/2021 at 7:29 PM, Paul 2020RST said:
Yes, that’s his opinion, and he has every right to state his opinion no matter how much you may disagree or not like it.
I agree...but won't stop me from stating mine either. Take care.
Traded my red 2019 Denali with the suspensionmaxx level kit and fuel wheels for a grey 2021 AT4 that the dealer had lifted after it was delivered from the factory. The total lift is 4 inches over the factory AT4 2 inch for a total of 6 inches along with 18 inch fuel wheels running 35x12.5x18 Toyo open country 3s. The kit is a fabtech with 2.5 dirt logic coil overs up front and 2.25 rear shocks. After some research it looks like more like a 5 inch lift plus the 35s which give it the full 6 inch over a stock truck. Rides fantastic, better than my Denali did with the level kit. 2 weekends ago I also took it out on the Burns Canyon Trail (So Cal) which runs from Yucca Valley (Pioneertown) up to Big Bear. It did awesome so looking forward to spending more time off road with this one.
See, right there is the problem. If I liked it I would get a "hey thanks buddy" etc.... But if I say don't like something than I am a hating piece of ******.  It's just wonderful how fragile the internet has made people. Blows my fricking mind.
5 hours ago, The Gibson said:
Tire size?  Stock height?  Looks perfect!
Toyo open county r/t 35X12.5R18. Ready Lift 2" sst lift kit but only installed on the front. Thanks!
35X12.5 BFG KO2s on Fuel Block 18X9 -12 offset. Billstein 5100s set at stock height, front mud flap bracket and mud flap removed. no rub, slightly kissing the felt liner in reverse at full lock.
On 4/6/2021 at 4:00 PM, lapoolboy said:
OEM 22's with 285/55R22 Ridge Grapplers.
What suspension setup are you running?  These are the tires I want to run on my factory 22's I love the look of your truck.
Still need to get windows tinted. Tire is Nitto RG 275/60. Wheel is Hostile Typhoon. Also did 2” level
Edited by JSB81
On 7/1/2021 at 9:08 AM, Trev Towers said:
I do. It should be somewhere around 1” of poke over factory. Also added a picture of the clearance at full lock. I wasn’t interested in going any bigger than the stock tire sizing because I didn’t want to impact fuel economy too much with weight, overall I believe the new setup is just a touch lighter.
On 7/1/2021 at 12:06 PM, Trevor Towers said:
Here are some more pictures for you as well. I included an image of my city MPG in just normal driving to show I can still maintain essentially the same MPG I was getting before. All city driving.
Finally got mine on. Fit great and no rubbing. 2021 Denali w/ 275/60r20 toyo open country at3 CC3D9A48-B5CD-4A2C-8BCF-020A2ABD9AEE.thumb.jpeg.f6f6969a49a5d5259d86095cb4e937b1.jpeg
On 6/30/2021 at 10:29 AM, Trevor Towers said:
Used this forum to pick out my specific wheel and tire set up so I’m returning the favor!
20” Vossen HF6-4s 20x9.5- +15 offset.
275/60R20 Falken Wildpeak AT3W.
it has a 3” Superlift lift kit. The tire size is same as stock on the stock 20” OEM wheels. There is zero rubbing at full turn. This setup gives a similar look to a leveled AT4.
I just got my 19 Silverado back today and ended kinda disappointed. I did not gain 3 inches in the front and have a pretty noticeable rake still. Do you happen to have what your stock measurements were compared to the new measurements are?
On 4/15/2021 at 6:19 AM, GK Hill said:
Daylight photos to follow😜
Are these gloss titanium?  I wish they had 18" with 0 offset.  Looks great with the Satin Steel Metallic.
Yes they are. I thought the color blended well too. Thank you.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
