8 minutes ago, SummitWhiteT1 said:
is that a K2 jump seat?
Yeah, out of a 2018 Tahoe that got converted in to a police vehicle.
1 hour ago, yankeeland71 said:
Color matched almost every that was black on the truck. Cognito 3" kit, tonneau cover, front/back black emblems. 35" Toyos Open Country. The rims are coming in this weekd2e82dec20b78934b8365dd339d12ad8.jpge2327c2ca703f891663c8156551ca24f.jpg
Sent from my SM-N975U1 using Tapatalk
Looks good.  All that’s left for me are the mirrors, should be done next couple days.  Don’t think I’ll do the front valence.
Looks good! You worried about the paint holding up on the textured pieces?
Sent from my SM-A705U using Tapatalk
Not at all, I am aware debri can damage the pain anywhere on the truck.
Kryptonite Stage 3 Leveling kit with the Fox Shocks. Hostile 20x9 +10 offset with 35x12.5x20 Ridge Grapplers. Very slight run on front felt of wheel well, just zip tied the felt back and no rubbing issues at all.
New truck in the driveway! Took advantage of some great incentives as well as  excellent trade equity. What an incredible truck!
Edited by EastCoast HD
First post and  no longer have the truck but a 2021 is on order.Same spec but white. Very impressed with the hauling. Our boat is 37' long and 10'6" wide and with full gas  is right at 20,000 lbs. You know it is there but cruise at 115 kph with no sway.
It doesn't know it has the 5th wheel dumper on. Amazing the difference a 5th wheel compared to bumper pull. Almost makes me want to get a 5th wheel boat trailer.
Been lurking for a little while...
Picked up my new 2020 LTZ Durmax a couple of weeks ago, but I have been waiting for the wheels to come in. Just got them installed.
Wheels are MKW Offroad, 20X9 with +25 offset and 285/65x20 tires. Pics below of the SLIGHT poke. I appreciated the pictures posted of various offsets to help me choose how much offset to get, so hopefully these will help someone else.
In addition to the wheels/tires, I have added Rough Country step bars (I chose these because the steps drop down quite a bit...and my wife is short ? ). Also, toneau cover and bed mat. So far, liking the truck very much.
On 11/11/2020 at 4:26 PM, Jesse Wagner said:
Picked up this 2020 regular cab last week
Looks good!!!!!!    What brand wheels are those?   Is that WT trim level?   Got any more pix of front,rear,side..
Those are black rhino armory wheels.  It has the lt package
Jesse, thanks for the info and pix..    That truck looks great!!!!!   Did you wrap or paint the grill and bumpers?          Wheel and tire size look perfect....Wheel and tire size please.
Did you install level kit or just crank the keys a bit?     I really like the look of this truck,good job..
Steve.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
