2000 Silverado only has 3rd and reverse
I have a 2000 Silverado 4x4 that has transmission issues. The trans was rebuilt several years ago and work fine until i parked the truck for a year. Upon initially driving away from where its parked the trans does its job and automatically shifts through all gears. Once I stop and go to take off it clearly isnt in 1st gear. Best i can tell at that point the only gear operating is 3rd. Ive tried manually shifting and that does no different. Any facts, ideas or suggestions would be appreciated.
Since it was parked for a year, check to see if mice chewed the wiring harness. Shifting is controlled by solenoids.
Check fluid level also.
As well, you might also want to get codes from the TCM, you'll need to use a better code reader than the basic ones that can only get codes from the engine (and there can be codes, even when the check-engine light is off).
Been a While but I believe it used to be that when the transmission was not receiving power to the transmission controller it went into default and that was 3rd forward gear and reverse. I am with everyone else on check wiring and connections.
