Help a brother out, level kit.
11 minutes ago, Londart2020 said:
You just have the coil overs and shocks? You don't think you need the UCA's
Sorry. I have Camberg upper control arms
  • Replies 33
Yes, and No...what is the difference? If you add 1.5" does having on the top of the strut mean there if less overall change in the angles? If so how do they both achieve 1.5" of lift? Whether you are making the bottom push up or the top push down you are still going to change the CV angle the same amount are you not?
I agree with you. The only difference is that the Gm lift comes with longer CV's and I'm not really sure why.
Sent from my SM-G930V using Tapatalk
my understanding is they arent dropping the differential so higher the truck the longer the axles need to be....is it necessary for 2" lift maybe not but better to have than not.....at 3-4 inches I would for sure want them or do the differential
the ready lift leveling kit 1.75" lift comes with UCA's. what do you guys think about it? would still have cv axle clearance/angle issue? Unless you change out to AT4/Trailboss cv axles which are longer?
