That's a little pricey but very stylish. And it solves mounting the controller by your legs issue. I might have to look into this one some day...
Only issue for me is that is where my 4x4 switch is so I don't think there would be enough real estate there. I would have to chose somewhere else to mount the dial.
Edited by mikeyk101
My service guy chose the mounting point.
Nice thing about a dealer install is I have someone to blame when it doesn't work.
Same for my tow mirrors, the trailering cameras (one on each tow mirror, one at the front, bed cam, etc.)
I'm having them install a Borla dual exhaust system later this week - I'll post up a vid in the Mods section.
Fortunately, my dealership is great - I buy all my stuff through the myChevrolet app and the associated web site ... I really gotta stop doing that!
Whenever I get a call from the dealership, after I placed an order and it's arrived, they just laugh and say "I see you've been at it again! Let's get you scheduled."
I've picked up more parts than I can count for self-install so when I walk in to the parts department, they know me by name.
On a side note, I am a wrencher when I need to be.
Many of the mods on my truck I did myself - I leave the electronic stuff to the dealer - as I mentioned, I have someone to blame if it goes sideways.
On my 535i BMW, just replaced the passenger side window regulator today - worked great but if  I made a mistake, I would only have myself to blame.
Fortunately, I have a long history with e32s and e34s so I think I'm good. :D
That’s what I was thinking when I first saw the photo. One idea (though I don’t know how well it would work in actuality) is to mount the controller inside the center console. In my years of trailering I’ve so rarely used the manual braking so having the controller not so quickly accessible shouldn’t be an issue.
15 hours ago, swathdiver said:
JL1 is the Integrated Trailer Brake Controller.  Integrated means that the wiring harness is different as well as the programming for the ECM, BCM and EBCM among others.  JL1 equipped trucks also include a Solid State Relay and the Integrated Trailer Brake Control module.
All you've done is buy the switch.
Now, this is the case for my older GMT900.  I'm pretty sure this still applies to the K2s, my memory is failing me.  The T1 guys, can just plug it in and it works if memory serves.
So for you Ryan, look along the driver's side frame for this:
I’ll look for this, I assume I should be checking for “JL1”?
16 hours ago, mikeyk101 said:
I think there is different ideas on what works best and that's why there are different options and opinions. As long as you get the trailer to stop with the vehicle, you win. In my case, I prefer a inertia/proportional controller and have the Tekonsha Prodigy P3 on mine. I like that it is able to sense how strong or how light I brake and proportionally apply the brakes according to that and it's immediate as soon as I step on the brakes. This is especially important in a panic stop. A timer based controller wouldn't give you immediate braking in that situation. Where there might be an issue with the proportional controller is on ice or snow and might not sense how hard you are braking if ABS kicks in. But this will probably be a non issue as the trailer will probably be parked in winter and not get used.
i've used the timer style for 10 years pulling trailers every other day, then recently tried Inertia, was very disappointed to say the least, it never put out enough brake force even maxed out,.  but I love the timer units better, puts more brake power to the trailer, so less wear on the trucks brakes. if you need more stopping power just hit the slider, stoopid simple designs is what works best
Well, you've got a pretty factory switch in your dash, but that's all you have.
GM is pretty cut and dry here.  Sell that dash panel and switch and get a nice aftermarket controller.
Quote
#PIT5241G: Adding Integrated Trailer Brake Controller RPO JL1 - (Mar 30, 2020)
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Cadillac
Escalade
2015-2020
All
All
All
All
Chevrolet
Silverado 1500
2014
All
All
All
All
Chevrolet
Silverado
2015-2018
All
All
All
All
Chevrolet
Silverado LD
2019
All
All
All
All
Chevrolet
Silverado 2500/3500
2019
All
All
All
All
Chevrolet
Suburban
2015-2020
All
All
All
All
Chevrolet
Tahoe
2015-2020
All
All
All
All
GMC
Sierra 1500
2014
All
All
All
All
GMC
Sierra
2015-2018
All
All
All
All
GMC
Sierra Limited
2019
All
All
All
All
GMC
Sierra 2500/3500
2019
All
All
All
All
GMC
Yukon
2015-2020
All
All
All
All
Supersession Statement
This PI was superseded to update Models section. Please discard PIT5241F.
Condition/Concern
Some customers may request the factory Integrated Trailer Brake Controller (RPO JL1) be installed on their Full-Size Pickup or SUV when the vehicle was not ordered with the option.
This is to advise you that, if the vehicle does not have the option (RPO JL1), it cannot be added to the vehicle.
Note: Reference the latest version of PIT5282 - which advises how to install an aftermarket trailer brake controller.
Ok, I'm a bit confused here, so please work with me. I just bought a 19 Silverado LD. It has a hole where the trailer brake controller usually goes.  It DOES have the JL1 option code, which reads "trailer brake controller". So with this, what do I need to make it work, or do I also go aftermarket? It also has the Z82 option code, for all it's worth. Thanks for your time.
Couple of questions.
Did you buy the truck new?
When you say "hole", can you post a picture? There is no hole (big slot) with the factory controller. You have a very small "slit" where the manual tabs are on top, and then a small square where the plus/minus buttons go (hope this makes sense).
The picture is the factory panel for a 4WD truck.
 See the source image
I believe adding the controller on a T1 is plug and play, search this forum, someone did it in 2019 or 2020.
I was a bit vague earlier. I bought used. there is a cubby hole where the brake controller is on JimCost's picture. It is a factory hole, with a little mat on the bottom. I can't get a pic right now. I would need to buy the part that he posted a pic of. I was wondering if that's all that is needed with the JL1 option. I will call the dealer parts dept. to see if they have any info. I do have an inside connection there, so they won't brush me off. will post results.
I talked to my "connection", in the parts dept., he did some digging around, and he said it would not work, even with the JL1 option. So I bought the GM under dash controller, complete with plug in harness, for $85, and installed it.
The factory brake controller CANNOT be added to the vehicle. Its NOT designed to be an add-on.  You have to use an accessory brake controller because the vehicle lacks the other components it needs to work.
  • 2 years later...
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
