This past Friday morning went and started my truck to get warm came back about 5-10 minutes later with the truck off lights still on and it’s throwing engine reduced power and p0641 code. Truck won’t turn over at all. Any ideas or tips? Thank you in advance
Edited by Brett Boyd
Added tags
56 minutes ago, Brett Boyd said:
Bump
Could be a few different things:
What Does the P0641 Code Mean?
Diagnostic trouble code (DTC) P0641 stands for “Sensor Reference Voltage “A” Circuit/Open.” It is logged whenever the PCM detects voltage that does not match manufacturer specifications on the 5-volt reference circuit.
If the 5 volts feeding the three-wire sensors is shorted to ground, it pulls all the three-wire sensor voltages to zero, and on some vehicles (like Fords), it will put the PCM to sleep so that there is no spark, fuel injection, or communication with the scan tool; thus there is no DTC for a shorted 5 volt rail on a system where the ECM/PCM has just one 5 volt rail because the ECM/PCM can’t communicate anyway.
If, however, there are multiple 5 volt rails, a short on just one of the rails won’t disable the engine. On a Ford, if any three-wire sensor shorts out, it kills the whole system. On a system with multiple rails, only one system goes down, but the engine will still run, albeit in limp mode (usually).
A 2016 Chevy Silverado, for example, has five different 5 volt rails. A short on any of these five rails will cause a different code to be set for each rail. The 5 volt rails on the Silverado each feed a different set of sensors.
Electric transmission control module designed for automatic transmission P0641 code is logged whenever the PCM detects voltage that does not match manufacturer specifications on the 5-volt reference circuit.
Rail 1 feeds the Engine Oil Pressure Sensor, the Fuel Rail Pressure Sensor, the A/C refrigerant pressure sensor, the Exhaust Pressure Differential sensor, the Camshaft Position Sensor. A short on this rail will set code P0641.
The other four 5 volt rails set different codes.
Rail 2 feeds Accelerator Pedal Sensor 2, the MAP sensor, and the Brake Pedal Position Sensor. That rail will set a P0651 if it shorts out.
Rail 3 feeds Accelerator Pedal Sensor 1 and the Intake Air Valve Position Sensor. That rail sets a DTC P0697.
Rail 4 feeds the EGR position sensor. That rail sets a DTC DTC P06A3.
Rail 5 feeds the Crank Position Sensor, The Cooling Fan Speed Sensor, the DEF fluid pressure sensor, and the Turbocharger Vane Position Sensor. That rail sets a DTC P06D2.
For an advanced, technical discussion of two-wire vs three-wire sensors and reference voltage, you can read our explanation here.
Note: The definition of code P0641 may be different depending on the vehicle manufacturer. Consult the appropriate repair manual or repair database for the exact code definition.
What are the Possible Causes of the P0641 Code?
engine control unit or ECU of a car with multicolored wires plug at foreground Wiring or connection issues can cause the P0641 code.
The code P0641 can be triggered by various issues, including:
  • Malfunctioning sensor
  • Wiring or connection issues
  • PCM problems
What are the Common Symptoms of the P0641 Code?
Keep an eye out for these warning signs if you are dealing with a P0641 code:
  • Check Engine Light is illuminated
  • Sensor-related performance issues
How to Diagnose the P0641 Code
Identifying the underlying cause of the P0641 code can be difficult, especially if you’re not confident with your automotive knowledge. In most cases, it would be best to bring your vehicle to an auto repair shop and seek the help of a professional for an accurate diagnosis.
Here is a video that can help give you a better idea of how this trouble code might be diagnosed:
How to Fix the P0641 Code
The P0641 code is a generic trouble code that may apply to various makes and models. While vehicles from different manufacturers may share common symptoms, that doesn’t mean that they also share repair processes. For example, the steps for diagnosis and repair for a P0641 Chevy code may differ from those required by a P0641 Hyundai code.
If you’re an advanced DIYer who’d like to fix this code on your own, it will be helpful to refer to your repair manual or get factory vehicle repair information from an online subscription service.
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
