I'm sure these types of questions are asked daily but I'm wondering if 2020 18" Trailboss wheels will fit my 2021 Custom that currently has the stock 20" wheels on it.
Thanks!
They sure will.  If you look up the parts they use the same parts except for the shocks and struts.  Even the ZR2 uses the same spindles, control arms and rotors.  The shocks and struts are different.
Awesome, I just read that the earlier (2018<) model wheels wont fit and got super paranoid. I assumed that they would fit but didn't know if the wheel wouldn't clear the caliper.
That is correct.   2018 and earlier (K2XX) will not fit any of the 2019 (T1XX) and newer without spacers.  I do not like spacers.
Neither do I.
You only need a 1/4"(5mm) spacer to clear the calipers to fit 2018 and older wheels on a 2019+ T1 truck. I test fit an old set I had for my Avalanche on my Trail Boss for someone else on this forum last week. I have to run the 1/4" spacer on my truck to clear the summer aftermarket wheels I have that were on my Avalanche also. There's plenty of thread for the lugnuts to grab on to and the studs are 14mm so there's no reason to be scared of a tiny spacer.
That’s good to know as I almost got wheels from a 18’ Silverado. I understand that the Trailboss may use different sized calipers compared to the Customs, which is what sparked my question.
No, all T1 trucks use the same calipers regardless of trims. The only different brake calipers are the dealer optional Brembo 6 piston upgrades.
New to the the entirety of truck jargon, what does T1 mean?
It's GM's designation for the new 2019+ truck platform. T1. The older 2014-19 LD trucks were K platform.
Gotcha, so, like fatwhiteboy (lol) stated, any wheel in a 19+ will fit, regardless of what trim package you have. So Custom rims will fit Trailboss, High County etc. and all vice versa.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
