Ford and gm are soon to be in bed together. Do some research for yourself you will find out that they are teamimg up to make trucks together
This vibration issue alone makes me not want to buy a new Chevy. This should not be difficult to find. You can put a frequency counter (?) on the dash and it will show you the frequency of the vibration and based on your speed you can see what part the vibration is coming from. There is also proper 9700 road force balancing which 99% of shops that have them, don't know how to use them properly. That's why I always stand there while they do it and help the tech and witness the Lbs of road force. Pinion angle is also critical. Pinion and u-joint angle to be more precise. I built a straight axle Dana 44 early 90's 4runner with a rotated front axle and rotated rear axle and CV shaft setup. Running 38's, That truck would do 100mph and not even shake your cup of coffee. Driveline tech is not something the $10/hr tire monkeys at the dealer know how to do. and the Silverado has leafs, so you have to deal with pinion pre-load also. IMO, the driveline is not setup correctly. The tires being balanced at the factory, in my experiences are spot on. This is a driveline math error. I'm thinking when the truck is unloaded the angles are way off, they probably have the thing setup for full load, or half load conditions. And yes, the longer the wheelbase/driveshaft the lower your operating angles will be, which mean smoother running driveline. GM should of coughed up the extra $20/truck and put a CV setup on the driveline.
Edited by FL335i
GM and Ford, GM and RAM they all work together more than you can imagine.
Ram subs out there transmission, vf makes them. I dont dought they all work together. Nissan is also making gm's new cargo van just putting a gmc badge on it. Ford and gm have been making there own trans forever. To competewith vf they are pairing up together to make to make a 9 and 10 speed trans. Trucks and suv's will have the 10 speed, and cars will have 9 speed.
The new ram has nothing to do with ford or dodge.
you're kidding right? The current generation if that is what you are calling the new ram has everything to do with Dodge. The next generation does as well. If they are not Dodge's design then please explain whose design they are.
The transmissions are Mopar designed http://www.allpar.com/mopar/transmissions/545RFE.html
Let's stop ****** in the wind and get to the point. These are $40-$50k trucks that vibrate and shake like Smokey's car from the movie Friday. I personally know another co worker of mine that bought a new Silverado Z71 back in late '12? and it vibrated so bad they bought it back from him. So I'm not so sure this issue didn't carry over from the old platform like baggage. What is GM's official stance on this issue? If a column switch cost them over a BILLION dollars (Yes Q1 reports were out today) I can only imagine how expensive it would be to put new driveshafts, or axles etc. in these trucks. Just seems like GM doesn't really want to address this vibration issue. If GM doesn't come out with a TSB/Recall the dealers will never find the true issue and just keep throwing everything including the kitchen sink at these trucks. Which costs them money and loses customers. I have more respect for companies that say, here is the issue, here is the fix. IE- BMW. my '07 335i was part of that big HPFP capper. They swapped it out, some injectors and threw a good warranty on top for 120k/8yrs or something crazy like that. And nobody is reporting failures with the new pump. painless, and properly executed. GM could use a few neurotic attention to detail people from BMW. I might just wait for the new Titan.
As for as the thread topic, has anyone had the rear differential swap that fixed the vib problem...
Does anyone have viberation when letting off on the gas to slow down? I am having this problem! I have not brought the truck in for the last recall on the transmission. I am hoping this will be the issue.
I did on the Silverado I traded in, my GMC doesn't do it. I would let off the gas and after a few seconds of coasting and the speed dropped it would start to shake but it was almost more of a pulse or surge, like if I had warped rotors and was applying the brakes but I wasn't braking just coasting. It didn't do it until I got around 10,000 miles and didn't do it every time. On my way to work there is a stop light at the bottom of a hill and if I got a red light and kicked off the cruse and coasted down the hill it did it more then not.
Any one notice their tires flat spotting after siting over night? My 2014 silverado did it with stock tires and the Dura Trac's I put on last fall (Dura Trac's on my 04 did it too). Now my Sierra I traded my Silverado off on does it too. After about 2 miles it's gone.
Got it back with a whole new rear end on Wednesday.
At first I thought not but I am getting more optimistic;
I have a tire issue that came up at the same time they were doing the rear end so I can't say it is fixed yet 100 percent as one of the rims may be bad. I rotated and road forced the tires today and I can say the following.
It is greatly improved specifically at 60 and above. That was my biggest complaint, bad vibration when cruising. It seems to be acceptable.
Tomorrow the tire issue will be addressed and I hope these things it is doing go away;
I have some vibration at 40-45 that goes away at high speeds, also getting some seat shake at high speeds.
I did on the Silverado I traded in, my GMC doesn't do it. I would let off the gas and after a few seconds of coasting and the speed dropped it would start to shake but it was almost more of a pulse or surge, like if I had warped rotors and was applying the brakes but I wasn't braking just coasting. It didn't do it until I got around 10,000 miles and didn't do it every time. On my way to work there is a stop light at the bottom of a hill and if I got a red light and kicked off the cruse and coasted down the hill it did it more then not.[/quote
my sierra does it at all times! Hills or not. Did they figure what the problem was with the silverado you had?
FYI, Chrysler manufactures the ZF 8HP in U.S. (Kokomo) under license from ZF.
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
