well, I got curious about the tires on my 18's, so I pulled out my window sticker and checked it. I paid an extra 350 for all terrain tires and have Wrangler SRA's... looks like I need to go back to my dealer for another issue haha
this is an absolute joke
Yea it isn't right. The SRAs are NOT all terrain tires, and to add to that they are extremely cheap tires. There is nothing about them that warrant a $200 or $350 upcharge. Ridiculous.
Doesn't look like we will have much ground to stand on for this case:
Goodyear
Not sure what that says cause it won't blow up big enough on my phone without it being blurry
I call BS on that. It's like GM decided to make a change, put SRAs on trucks that paid for the all-terrain option, and asked Goodyear to put that little all terrain logo on the website. There's no other website that consider SRAs to be all terrain tires. They are cheap, highway all-season tires.
It even says in the description on their website they are "original equipment". When you pay for the all-terrain upgrade, it says right on the window sticker "Replaces standard tires".
Regardless of if they are or aren't all terrain, my 2014 had these exact SRA tires on it, WITHOUT the $200 all-terrain tire option. Many other trucks do as well, right now, go look on a lot. So what did that $200 get me? Nothing.
Furthermore, tell me what tires WOULD have been on my truck, had I not paid for the $200 option. Probably the same tires...or, Goodyear Eagle LS2 tires, which are the same quality tire, cheap, pretty much the same price as SRA. On TireRack, the Eagles are actually $1 more expensive, lol. Some upgrade these SRAs are...
Edited by mikegmi2
Unless these Eagle ls2 tires are ruled as the fault for my vibration, they have been a pretty good tire. Good street manners and do well in inclimate weather as well. Did pretty decent in my buddies muddy ass field while I was towing a trailer as well. Maybe I'm the only one who's had good luck with them so far.
Now if they're the cause of my vibration then they suck ass lol
My first 14 had ls2 tires and had the shakes. I also drove a HC with ls2 20's and it had the shakes as well.
I have the vibrations as well, just not sure if it's the tires fault or not lol
my dealer already confirmed that the SRA's are not an all-terrain tire, everyone knows that. confirmed by tirerack as previously mentioned, my dealer is looking into getting me real A/T tires, and has told me to urge everyone to contact GM Customer assistance at 1-800-222-1020 regarding EVERY ISSUE WITH THE TRUCKS.... even they are sick of dealing with the complaints
http://www.tirerack.com/tires/tires.jsp?tireMake=Goodyear&tireModel=Wrangler+SR-A&partnum=665TR8WSRAOWL&autoMake=Chevrolet&autoYear=2015&autoModel=Silverado+1500+4wd&autoModClar=Crew+Cab
Goodyear's website says they are AT so GM is not really cheating anyone even though the SRA's are cheap tires. They are also standard equipment on alot of other 4wd "off road" trucks. If GM put actual LT AT tires then people would raise hell about their gas mileage being below what the window sticker says it should be. If you don't like the tires then don't buy the truck or put on the set you want like everyone else does.
Problem is the manufacturer can market them however they want as I doubt there is a standard for what make an AT tire. And why wouldn't GY try to upsell the product. Typical marketing at work. And GM being stingy. I agree with part of your statement on the LT,s, I wouldn't expect an LT tire to come on the 1500 trucks. In any case I think most agree the GY's are not worth a $200-$300 upcharge and GM could be putting a better AT on with that upcharge. Looks like GM is getting away with it again just like the "normal operation" vibs people feel. Buy still I wonder why some like myself get the Bridgestones then. Is it a 4x4 vs z71 thing? Or an assembled in Mexico vs Fort Wayne thing? Or just a regional thing where final vehicle destination being a southern or northern state determines it.
let us not forget that even those trucks without the "upgrade" have WRANGLER SRA's which my dealer agrees is not an A/T tire, so no matter how you look at it, they owe us a better tire. I'm not paying an extra 350 to for the tire that come stock on the truck anyway.
Edited by Jesse D
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
