But that's just powertrain warranty, right? Infiniti and Mitsubishi offer a 5 year/60k mile bumper to bumper warranty. If GM did that, I would consider it a major improvement.
B2B is still 3 year/ 36k miles
Someone needs to remove the tires from the wheels, put the wheel on a hub-centred mandrel, and measure the radial and lateral runout with a proper dial indicator, not the measurements that May or may not be done on the Hunter RF machine. I don't trust that stupid little arm that the Hunter machine uses. And when we see that every tire vibrates on these trucks, including totally different make/model of tire, I can't believe every tire manufactured is defective. It's too preposterous to believe. Gotta be the wheels. Or the hubs. Or the hub-centric fit is too loose.
Has anyone put aftermarket wheels on? Hub-centric or lug-centric? Result?
I picked up my truck today after multiple road force balances, new driveshaft, new front tire and 4 new shocks and I have no change in the center console vibration. Now the dealer working on it wants me to bring it back in and have the field rep go over it again. This poor dealership has had several trucks in for the same thing and can't get them fixed. I actually feel sorry for them.
My recent issues have seemingly been solved by another tire rotation and balance. All four wheels out of balance from the last balance about 7k miles ago. Wondering if these 20" Goodyears just go whacko after 5k miles? Anyway, much smoother ride at 78 mph to and from work today. Feeling much better about my deal...good luck.
I've seen where a lot of people were concerned with this being related to the larger diameter rims or the goodyear tires but I have the regular 17in rims with bridgestone duelers. One dealership has the pico pointing to the driveshaft while another shows it being a tire/suspension issue. As the dealership told me....nobody knows whats going on. Same problem since late 2013, you would think they'd have this figured out by now.
Does anyone at these dealerships use flange plates to hold the wheel on the balancer by the lug holes instead of centering it though the center hole with a cone? There aren't too many wheels that are not hub centric, but there may be a few and those simply cannot be balanced properly without using special adapters.
I think the arm you mention on the Hunter balancer measures the rim width, diameter and offset after the wheel is mounted and automatically enters these parameters into the machine. I personally prefer balancers with a manual data entry. This way it is difficult to make a mistake. After you mount the wheel, you typically enter the following data: rim width in inches, rim diameter in inches, and then the rim offset (distance from the fixed point on the machine to the rim). if you are not sure about the first two parameters, you measure them with a hand caliper supplied with the balancer. The last parameter is often entered in millimeters on European heritage machines such as Bosch, Kwik Way, or Sicam balancers. You measure the offset with a built in spring loaded arm on the machine. However, unlike with the Hunter 9700, you must enter the data on the keypad manually.
Edited by pm26
My 2015 Sierra Denali 6.2 8 speed was dropped off at the dealer yesterday with the same vibration.
Thud occurs normally when rolling up to a stoplight and stepping back on the gas.
Vibration occurs when accelerating with a light foot as the engine revs through 1500 to 1600 rpm. Also, at any stready speed that has the engine at that rpm. 47 mph, 58 mph and 67 mph. Almost like the transmission is slipping or the computer cannot pick what gear its wants to be in.
Service writer wrote it up yesterday afternoon. This morning after a short test drive and 5 minutes of research the dealership calls me to tell me it is a issue with the torque converter. A known issue. A new and improved torque converter will be available soon or I can request a new transmission with the new torque converter and latest software/firmware control updates. I requested a new transmission because who knows what this junk one has done to the trans. All of this is supposedly documented in a Technical Service Bulletin that came out last month- mid-October 2015. I did not get a bulletin # and could not find anything on line about but I am driving a dealer loaner for the next week or so while they get the new transmission in. I did not have to speak to anyone other than the service writer. Hopefully my truck comes back fixed and these issues go away. Already had the ujoints on the driveshaft fixed a few months back.
After warning GM with a LEMON LAW ,I got a response to the months of my truck vibrating .
Tuesday I have an appointment with the field rep at Ed Morse Sawgrass FL
I must say that this dealer has been fantastic , when ever my truck has been in ,they have organized alone for me ,
They have done very thing that the factory have suggested .
Well lets Tuesday my truck is back at the dealer now lets see GM wiggle out of this .
My not sure of what my options to the out come will be if GM can't fix the vibration .
A new truck ?
or a refund? less the 15000 miles Ive driven ?
I have seen the new 2016 Sierra , with the modified engine mounts
or a new 2016 Toyota Tundra .
I think that the Toyota 5.7 liter engine is an old design , it defiantly isn't as fuel efficient as the direct engine 5.3 liter GM engine . But Toyotas have a reputation of reliability .
Ford ? look at the you tube videos of the crash tests of the Sierra and the Tundra and then the new aluminum F150 double cab and single cab , those things crumple like an old coke can , no thanks .
Also the new ecoboost engine produce impressive HP and torque figures . BUT will they last for 150000 miles plus ?
GM and Toyota will .
So lets see what solution or fix GM have .
Do what makes you feel good. Toyota are good trucks and they haven't changed anything for years so it will probably be the most reliable but with a gas mileage penalty. I don't see the ford aluminum body being any weaker than the paper thin sheet metal that GM puts on our trucks so I think you are way off base on that one, the frame is what determines how a vehicle handles a crash and the ford has a steel frame. I also have my doubts on turbo engines but I also have my doubts on Direct Injection with cylinder deactivation lasting 150k miles as well! TIres and rims out of round on a sensitive frame is the reason for most peoples vibes. For those with the more serious vibe problems I am betting that GM knows exactly what the problem is because after 2 years of this even their dumbest engineer should have figured it out by now. They just don't want to do anything about it because it will be to expensive.
Agree 100% with everything you said. I had a toyota before the the gm 0 problems ford before that this is the first gm truck i have owned since 1995. I like the truck alot the ride could be alittle better off road. Had to have the tires (275/55/20 chrome rim) replaced with (michelin ltx m/s2) at 1000 miles they were flat spotted from the beginning. I have a vibration between 75 and 85 worst at about 82. I only get up to about 63 to 65 on my daily drive so the vib is no problem. Few days ago went on a 300 mile round trip where the speed limit was 70 so I hit 75 + alot and on smooth new pavement the vibration was bad. I'am going to get the wheels balanced and see if it helps. When I had the tires replaced the right front wheel had a line of inside weights about 5 inches long from the factory when they balanced them it still took alot so they put that wheel on the right back. I told them that wheel needs to be replaced but there ears were stopped up. Once I get them balanced going to mark the rear tires at the valve stems to make sure they are not turning on the rim. If I had to drive it everyday at 75 plus and the vib could not be fixed I would go back to toyota or ford as much as I like the gmc.
Edited by southern_sierra
And on the other hand, their new trucks are so cheap that you can trade up every six months, just using some spare change. :crackup:
Edited by pm26
Well, there is no substitute for Chinese quality.
I purchased my 2014 Silveraldo Z71 w/5.3L a year ago, i have complained about a clunk and now i have this vibration going on. I am not at all pleased with my NEW truck, GM just keeps feeding me BS in hope that i will stop complaining. I have been a loyal GM man all my life(30t years), this has changed me. I will not buy another GM, i will research Ford, Dodge and Toyota with great detail. I've looked at various forums to see a large number of people with the same issues and GM does nothing with any substance to resolve these issues.
There are a lot very loyal GM people out there dealing with issues that i feel are unacceptable!
I finally had enough of my vibration and 2 different dealers not wanting to fix it or even attempted to fix it. Always got the whole "it drives like its intended too" so I traded it in on a new truck.. Sad day it was because I really like the truck a lot!
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
