If you ask gm none of them shake/vibrate. Was told by dealer yesterday tech didn't feel anything. I guess I have imagined my trucks vibration.
All depends on the dealer, My original say then know nothing about it, havn't found any with it, and couldn't replicate it in my truck. I went to another dealer and they admitted to it, immediately felt it, and tried to fix it.... unsuccessfully, but they tried.
Original dealer stated they didn't feel it but it registered enough on pico that they replaced rear tire. This was the second time the tire was replaced. The first time was due to bad rf numbers. They acknowledged it both times. After telling them it still shakes they said nothing else they can do as they can not replicate at interstate speed as they have no interstate access. Essentially told me to take to another dealer. I did and no vibration per them but I highly doubt pico scope was hooked up. It's just frustrating to pay 500 plus a month for a product that doesn't perform as it should. Actually last dealer told me they felt it when in V4 mode. Said that was normal lol. Anyway rant over. Edited by sk252
I typically don't drive on the highway with the windows down because I don't like the wind noise, but there is a weird pressurization type of thing with them down., maybe a little worse than other cars in my opinion, but I can't say for sure. never noticed any change in vibration from it.
FWIW, Crack the rear windows a little and the buffeting sound disappears.
If I have the windows down, I normally have all 4 down to the same level
That is an interesting read, just one note, my second 2014 had the factory Borla exhaust option.
I have my vehicle in for the second service regarding this issue today past the Pico scope and they tell me at the vibration that they admit they feel is within normal means when the video that I have clearly shows otherwise I took both the service manager and the foreman for a ride they both can feel the vibration the foreman will admit it the service manager says he doesn't feel anything out of the ordinary that sets it apart from any other truck I'm at a loss at this point because they aren't willing to go any further with it being as it passed the test the truck is a 2015 Silverado LTZ 20 inch wheels with 8 thousand miles.
Read between the lines of what the service manager said.
He can honestly say he does not feel anything that sets it apart from the other trucks they have had on the lot.
go to a different dealer. or wait a month then go back and say it got worse
Just to offer a ray of hope, my 70-75MPH vibration has been fixed and after 5000 miles is still vibration free. My fix was two steps; torque factory U bolts to 80 ft-lbs, and then balance tires. The U bolts resolved about 80% of my vibration and the tire balance resolved the remainder. I know there seems to be different causes of the vibration, but I can report my truck is now very smooth, so at least some cases can be fixed. My truck is a 15 double cab, 4x4, z71 with 20 inch wheels.
already had the U-bolts checked as there was also a service recall for them not being tight enough on many trucks.
Ok guys here is an odd one, when I bought my 2015 Silverado 1500 Crew Cab Z71 with 18" wheels it rode like butter and smooth as silk.
Now at 28,000 miles it rides like a tank and has a fairly good shake that I can't get rid of.
Do you think it is the U-Joints?
Edited by scooter484
At 28000 miles it could be anything.... probably totally unrelated to this thread lol. You could have a strut or shock bad, tire balance problems, wheel bent, sticky u joints etc. If it rides different you probably need shocks and struts... yes 28000 miles is pathetically early but the factory parts aren't exact top quality lol.
Sent from my SM-G900W8 using Tapatalk
Edited by 1994Vmax
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
