On 10/18/2017 at 9:11 AM, SWOYER said:
I'm having a hard time locating the part numbers for the Original Denali style steering wheel trim for a 2014. Also, the thin trim around the radio controls. I'm changing out my interior from silver to burnish and these are the last two pieces I need, just need to find the part numbers. Seems like these are hard to come by on ebay.
To change the trim on the wheel probably requires a whole new steering wheel.
  • 4 months later...
Forgive me if this is covered elsewhere. I have a 2014 extended LT Silverado that I removed the mudflaps from. I don't want them, and they are GM. I want to add the little rock guard pieces instead. They use the same mounting holes as the mudflaps, so now I have exposed holes and clips. Can these be purchased by the set? Where is the best place to find these? Thanks
If the little rock guards are GM parts then go to the GM accessories web page and get the part numbers. Then i would go to Ebay who has better pricing, free shipping and no tax.
Anyone able to give me some diagrams with part numbers for a 2014 crew cab ltz wiring underneath the bed please?  A cable has been cut and I need to figure out what the part number is.
Thanks
That's the problem I am having. The mud flaps are on that page, but the guards are not unless I'm missing them.
On 7/13/2018 at 9:04 PM, Tahoe02 said:
Check these part numbers and see if it is what you are looking for GM part # 22801024 and 22801025. Found these on Ebay.
Thanks,
 I believe those are it. Wish they came as a pair. I need the fronts as well so that is next.
Does anyone know if a stock front bumper for a 2016 Sierra 1500 would fit on a 2014? I replaced my stock one and am trying to sell it so it's not taking up any room.
Anybody have access to a wiring diagram- 2014 Silverado forward collision alert system?
frustraded and need help, thanks in advance
  • 4 months later...
I have a 2015 GMC Sierra Denali with the cocoa Dune interior. I am looking to replace my microphone that's above the visor on the driver side. It looks as if I pull the headliner down and just replace one section of the microphone where there is a clip to a harness. Problem is I can't find a microphone let alone the same interior color. Does anybody have a part number for this cocodune microphone, wow that rhymed. Anyway I appreciate any and all help thank you very much.
I am replacing the microphone because it was damaged by a leaking shark fin antenna. I believe the antenna is fixed however the microphone must have got corroded. Just some additional input maybe it'll help someone else downline.
  • 6 months later...
As I was adding gas to my truck today, i noticed that the tanked moved when i placed the handle in. Hopefully someone can give the part number or name for the part that's missing where the tank connects to the body (by the fuel door).
Thanks in advance!
Has anyone purchased a service manual (digital) off of ebay?  I see a few different available.  Just wondering if they are legit.
  • 3 months later...
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
