26 minutes ago, Granite7 said:
Upgraded to the aluminum skid plates.
4c52e134b2e6af3149f8867803d625fd.jpge6d3c3c24b4f1aa4b403bbc05f1a4c4d.jpg39c5a3dad42097337f641d61d49e36f4.jpg
Looks great, did the same thing to mine over the summer.
Did you buy the kit with all 3 pieces, and replace your existing skid plate cover?
part numbers for that bad boy?
22 minutes ago, doubeleive said:
added some led lighting
That looks pretty cool looking!!!
Nice 3D effect with the blue color.
Service Component, Under Body Shield 23135959 1 $65.52 Shipped
Service Component, Under Body Shield 23135960 1 $65.52 Shipped   are the part numbers I ordered from GMPartsdirect in 2018. Z71 should already have the metal skid plate from the factory for the transfer case.
Edited by JimCost2014
Yes, I bought the kit on eBay a few weeks ago after a member posted their upgrade. Was that you? If so, thanks!
I did replace the existing skid plate. I banged it up on a hunting trip in September and the third plate already had some rust on it.
This instructions list 23176882.
The auction listing was for 23176881 2015-2019 Cadillac Chevrolet GMC OEM V8 Engine Under Body Shield NEW
Was not me, never got around to posting any pictures after it was done.
I bought mine from GMPartsdirect.com, along with extra bolts.
my camera doesn't pick up the color just right, it's pretty close just not 3d looking in real life ?
Too bad, almost looks like the floor of your truck is made of glass in the picture.
Where did you mount the lights? And how?
the interior light "wire" is right under the dash on the drivers side plugged into the bcm, i just tapped into that wire and then I used the 10mm mounting bolt on the lower kickpanel as the ground and then just ran a led strip under the edge of the dash to the passenger side, zip tied it at both ends so it is tight like a tightrope, it's not in the way of anything and if it needs to be moved for any reason I can just cut the zip tie on the passenger side and pull it out then put it back later. I ran the wires so they are behind the factory wires and out of the way of getting yanked or pinched, the power wire is fused so if it shorted out for any reason it will just pop the fuse on the led strip and not harm anything else.?
Full exterior detail.. clay bar, ceramic, wax/sealant plus fixed what chips I could on the front bumper. 6 hours later and I’m totally exhausted lol.. the most time consuming part was cleaning/waxing/sealing the wheels. All of those nooks and crannies on these honeycombs really takes a bit of time.
Edited by mistermcgoo
  • Like 9
Today I finished installing bus bars in the bed. Right now it is covered with a tonneau, but I plan to order a topper between now and Black Friday. I plan to keep the truck for a long time, so I don’t trust T-taps for a permanent wiring solution. These bus bars will help with modifying the bed lighting for a switch in the bed. It will provide a solid ground for my CHMSL circuit. It will also make it easy to wire an air compressor and accessory outlets in the bed.
2b13f894bbcb3da5ffe8b71b0ca3364f.jpg7aef31e33c16aa78f338575dd98d1025.jpg86ac3eb5e4136418f2767c29c514e84c.jpg
a previous thing I did was swapped in a 220amp alternator (kw5) from a 3500, it's plug-n-play just make sure you get the one with the correct pulley as there is 2 different ones, decoupled and steel
Installed JL Audio’s front console sub and a lil RF 500.1 amp. Much better than stock. Also ordered KO2s for my feet
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
